  • July 07, 2025, 07:43:39 PM
Author Topic: Wing Waggle Trim Issue Solved  (Read 1273 times)
Offline Tim Stagg
« on: November 18, 2016, 09:13:41 AM »
I would like to thank everyone for their suggestions and theories.
I think I have 95% of the problem solved...it was a yaw issue and below is what it took to fix it. Still minor trimming to do...but for the most part the chip is flying well...looks like it may see paint after all.
Motor rotation changed to tractor
Motor adjusted with very slight right offset.
Trim tab used...(NOT PBR)...sorry Dan  :)!  worked well with right offset...(I am cutting a trim-able rudder now to fine tune the amount)
Removed moved tip weight to just an 1.3 ounces
Adjusted the readouts further forward...they are now about 1/2" behind CG.....this seems to work best...I tried several locations for and aft.
Again, thanks for everyone's help
Tim Stagg
Offline Fredvon4
  • Central Texas
Re: Wing Waggle Trim Issue Solved
« Reply #1 on: November 18, 2016, 10:30:32 AM »
Tim
Thanks for the several threads//// I learned a lot
Fred von Gortler IV
Online Steve Helmick
« Reply #2 on: November 18, 2016, 11:11:54 AM »
FWIW, the specific tipweight amount doesn't help us understand the problem because we don't know the wing offset (if any), or how heavy the inboard wing half is, relative to the outboard wing half. It's all about the CG of the model in the span-wise axis. Make sure your hinged rudder is rigidly fixed so it won't flutter or flex. I'd wonder how much (if any) of the fix was from changing to the LH prop.  D>K Steve
« Reply #3 on: November 18, 2016, 03:04:51 PM »
Sounds like a very conventional setup now...Surprise, Surprise!
Where is the CG?  Preferably in % of MAC.
« Reply #4 on: November 18, 2016, 07:46:40 PM »
Nothing like going back to basics. H^^  Glad it is working for you.
Online Dan Berry
« Reply #5 on: November 18, 2016, 07:52:00 PM »
Hey now. I don't say others don't work, I just said PBR cans work best.
Glad the plane is settling in.
