  • May 06, 2024, 03:52:12 AM
Author Topic: ...wing jigs...  (Read 4777 times)
Offline Bootlegger
...wing jigs...
« on: February 18, 2017, 05:02:03 PM »
 I picked up an adjusto   jig and wanted to see who else uses one and how do you like it?
 Do you have any suggestions/advice on using one?
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Will Davis
Re: ...wing jigs...
« Reply #1 on: February 18, 2017, 05:09:41 PM »
The only wing jig I use, 25 plus years.. Good jig
I do not use the rib drill out fixture, just draw a centerline in rib, mark the holes by measuring  from rear of rib  and cut  individual  holes .
Will Davis
"Carolina Gang"
Offline eric rule
Re: ...wing jigs...
« Reply #2 on: February 19, 2017, 11:41:33 AM »
I've used the Adjust-O-Jig for years. One of the best ideas ever.
A couple of things you may wish to do to yours to make it even better.
1) Unless you plan to build dihedral wings make sure you lock the bottom bar at the hinge. A simple way to do this which allows you to change back to standard for building dihedral wings is to install a metal bar that is locked to the bottom bars using bolts. Easy to remove it needed yet very solid otherwise.
2) get some "thinserts" And install them in the galvanized pipe. The threads in the thin wall pipe will rip out  if you over tighten the pipe bolts.
3) Since many of the models we build will have fairly long ribs you will want to make up a number of extensions to allow you to create a third line jig jig holes in the wing to support them. I used 1/8 plywood sticks 1/2" high and 7" long. Three holes drilled along the center line at 2" intervals allow you to suspend a third rod out in space. This helps keep everything properly aligned.
Eric
Offline frank williams
Re: ...wing jigs...
« Reply #3 on: February 19, 2017, 01:44:29 PM »
I've been using hardwood 1x2's
Re: ...wing jigs...
« Reply #4 on: February 19, 2017, 04:36:16 PM »
I've been using Ajusto-Jigs For over 25 years.  It's the only jig I use except Hunts Lost Foam Jigs.
I strongly recommend mounting the Jig on a piece of 3/4 inch plywood and screwing two long pieces of heavy angle iron to the bottom.  This makes the jig much steadier to work on and prevents warping of the base that can make it unsteady.  I also caution you not to tighten the end screws that allow the jig to rotate. too much or the plastic can break!
I also recommend not using the drill templates for rib positioning  they wear out quickly and then the holes in the ribs can be too loose and/or misplaced.  The method I use that works very well is to carefully stack the ribs together according to a common reference like the trailing edge if the trailing edge is straight or spar notches if they are aligned and pin the ribs together by driving T-pins through the ribs (from both sides if necessary).  Mark the location of the necessary locating holes on the outside rib (I do this by holding the last rib against one of the rib locators on the jig).  Then drill the jig wire holes with a drill Press.  If the pins interfere with getting the ribs to lay flat simply use a piece of hardwood or flat plywood with holes drilled where the pins are located, on the drill press and place the ribs on the wood with the pins over the holes.
Do all of this very carefully and you will have a very nice straight wing.
Offline Target
  • C/L Addict
Re: ...wing jigs...
« Reply #5 on: February 20, 2017, 12:22:26 PM »
Where do you buy an Adjust-o-jig?
Chris
AMA 5956
Offline Bootlegger
Re: ...wing jigs...
« Reply #6 on: February 20, 2017, 05:15:31 PM »
 Chris I sent you a private message...
Gil Causey
AMA# 6964
Offline Bootlegger
Re: ...wing jigs...
« Reply #7 on: February 22, 2017, 05:41:03 AM »
 Eric Rule, I sent ya a private message..
Gil Causey
AMA# 6964
Offline Target
  • C/L Addict
Re: ...wing jigs...
« Reply #8 on: February 22, 2017, 07:34:23 AM »
What diameter are the rods that run through the ribs?
Thanks.
Chris
AMA 5956
Offline Bootlegger
Re: ...wing jigs...
« Reply #9 on: February 22, 2017, 02:09:00 PM »
 Chris, the rods are 5/32"  in diameter, hope that this helps...
Gil Causey
AMA# 6964
Offline Target
  • C/L Addict
Re: ...wing jigs...
« Reply #10 on: February 22, 2017, 10:29:56 PM »
Gil, yes, thanks. That helps.
I have a line on two adjusto-jigs, but they are missing the rods.
Chris
AMA 5956
Re: ...wing jigs...
« Reply #11 on: February 23, 2017, 07:04:34 PM »
They're just 5/32nd music wire.  I've replaced a couple of them on one of mine due to rusting.  They're usually available at the local hobby shop, or Michaels!
Offline RK
Re: ...wing jigs...
« Reply #12 on: February 23, 2017, 08:09:15 PM »
OK I've been looking for a good wing jig.....Where Can I buy one?
Thanks RK Flyer
If you come to a fork in the road,,,,Take it!
Offline Leester
Re: ...wing jigs...
« Reply #13 on: February 24, 2017, 06:38:24 AM »
These are no longer in production, Put a want add in the classifieds. There are some around you just have to find one in good shape.
Leester
ama 830538
Offline peabody
Re: ...wing jigs...
« Reply #14 on: February 24, 2017, 06:55:12 AM »
John D'Ottavio came to  GSCB meeting almost 30 years ago and explained that he built most of his wings on a 2" X 8 piece o pine and eyeballed them straight...
Re: ...wing jigs...
« Reply #15 on: February 24, 2017, 12:42:48 PM »
Some of the straightest wing that I have built were done with out a jig.  Using straight pins, rubber bands and tape.  The advent of CA is what really helps to a point.
Offline Tony Drago
Re: ...wing jigs...
« Reply #16 on: February 27, 2017, 10:18:10 AM »
Some one want to float me a loan? Granted it's new in the box.
 On Ebay
A-Justo-Jig ------ Wing Jig ------ Unused
 Unused http://r.ebay.com/qmAyQ9
Offline Mike Griffin
Re: ...wing jigs...
« Reply #17 on: February 27, 2017, 11:16:27 AM »
 On Ebay
Tony I went to that link and could not believe that price.  People have lost their minds.
Re: ...wing jigs...
« Reply #18 on: February 27, 2017, 11:28:09 AM »
 On Ebay
That's positively crazy.  I guess it's true that some people have a lot more money than brains!
Offline Tony Drago
Re: ...wing jigs...
« Reply #19 on: February 27, 2017, 12:52:15 PM »
I agree. Wonder what it would cost to reproduce one.
Offline Tony Drago
Re: ...wing jigs...
« Reply #20 on: February 27, 2017, 12:54:01 PM »
At least the S&H is free.
Offline Allan Perret
  • Proverbs
Re: ...wing jigs...
« Reply #21 on: February 27, 2017, 01:19:07 PM »
That concept could be duplicated for $60~$70 in materials.   Using 5/16" arrowshafts would only need 3 supports per wing panel instead of supports between every rib.
Allan Perret
AMA 302406
Slidell, Louisiana
Re: ...wing jigs...
« Reply #22 on: February 27, 2017, 03:51:24 PM »
Well yes but I think you would be losing one of the best features of the Ajusto Jig, which is the fact that the all wing ribs are held tightly in three axis throughout the build including the application of the sheeting of the LE and TE.
I agree that the materials should not cost more than about $60 maybe considerably less.  If the materials were purchased in advance for 20 or so Jigs I would think it could be considerably less!  Most of the Jig could be built from plywood except the main tube that holds the rib supports and it's just 1" aluminum tube, and the jig rods which are 5/32 music wire!
Offline eric rule
Re: ...wing jigs...
« Reply #23 on: February 28, 2017, 10:16:59 AM »
You should check out the pictures of the wing jig in Mike Griffin's vendor corner (Griffin Building Service).
What Mike is showing is my rendition of an Adjust-O-Jig. The uprights extend above and below the ribs so all you have to do is turn the jig upside down in order to finish the wing. Like all jigs it is designed to keep the leading and trailing edges on the same plane through out the building process. It may not be pretty or sparkle or cost an arm and a leg ....BUT IT WORKS!
Offline Tony Drago
Re: ...wing jigs...
« Reply #24 on: February 28, 2017, 10:43:15 AM »
Eric.
 So you finally found a good use for all those extra landing gear blocks.
  Seriously, I like the  concept. Do you sell these.I looked on your web site and could not find it.
Offline peabody
Re: ...wing jigs...
« Reply #25 on: February 28, 2017, 02:19:05 PM »
Windy had aluminum end pieces, drilled and glued to a piece of marble......used 3/8" stainless rods.....always waxed the rods....there are videos with the process.
Have fun!
