So the OS 35s weigh the same , or less , than the Veco 19s ( Whats the Lightest .35 thread ) . This got me thinking .
Id got 88 mph out of it , in speed . And it already had the larger intakes in it . Two 21/29s oe er something ( two 21 / 40s ,
but theyd gone !
) So out came the olde wreck for a bit of refurbishment . Cut down the P-38 tanks and dragged it out to
Cowra meet . The fuel was dodgie & the tanks dodgier , so I canned them ( 44 Gal. can ( 50 US Gal. ! )) .
The other day I got a piece of sandpaper while the thing was on the bench . Next thing you know ( 5 hours later ) Id rasped off all the top
covering to bare wood , and resheeted the resheeted areas Id used thinned balsa cement to shrink & distort .
Of to the City on a burning hot day , frazzle frizzle . Id found some tanks with the right side feed bore , but the 9 x 6s Id just put on the Whirlwind
so I couldnt find them !
Ended up with the 10 x 6 top flite nylons , which are a bit bigger , heavier & meatier . And no Filters .
First Go the silly tank starp parted on the inner , out of the wingover . Id brought the others so doubled it .
Next Go , Got the Outer fired up and the inner kept leaning . So was two turns out more , at the launch . ( obviously a bit of grot in the thing )
The Inner went Full rich , and the Outer Full Bore ( sounded like it was right on song ) UNFORTUNATELY on 70 Ft of .018 this was De Ja Vu
of the ' Turn Left , three Rolls , and Go for The Pilot , Inverted trick . Or so it appeared to He , for the Moment .
I mustve snatched it a bit straight at some stage , but the disadvantage of not walking to the field is your not limbered up & loose , and ready to SPRINT .
Therefore apart from the tailplane , and a nacelle , and the outer wing , and most of the new covering , it was ok. I couldnt give it away >
Someone suriptitiously retuned it to my car boot .
A few days later I slotted the outer back in place , and got the rasp out . Took all the painted covering off the underside back to the wood ,
And got the thing generally nailed back togeter . Thought'it'd had spruce spars, but theyre not .
It dates back to 002 , so im lothe to scrap it unless ive replaced it . Busy on other things so it looks like the No 1 Rat Rod'll be airwothy ? again soon .
But do I strip of the rest or just do it as I go .
