  • July 18, 2025, 03:19:03 AM
Author Topic: Engine crutch for canted mount  (Read 2478 times)
« on: April 18, 2017, 06:59:41 PM »
Are there any plans that show how a side exhaust engine is mounted so the muffler is center on the bottom. I remember seeing a CL plane but don't remember where.
Thanks in advance
Offline John McFayden
Re: Engine crutch for canted mount
« Reply #1 on: April 18, 2017, 07:46:04 PM »
The Ringmaster Deluxe is a profile designed with a canted engine.
« Reply #2 on: April 18, 2017, 08:00:44 PM »
Sorry.
Looking for a full fuse.  H^^
Offline Mike Haverly
« Reply #3 on: April 18, 2017, 09:39:34 PM »
Use an RC mount and mount it to F1.  It's really not much of an engineering problem to figure it out, it just has to strong.  I did it on a modified profile Cardinal with a Magnum .36 on a pipe, similar to what Randy Powell did on his Ringmaster Deluxe.  A full fuselage would be much easier.
« Reply #4 on: April 18, 2017, 10:29:09 PM »
Al Rabe did it on his Snaggle Tooth P-51.  I do not know where plans can be found.
You might find something on one of his several threads.
Eric Viglione
« Reply #5 on: April 19, 2017, 05:32:20 AM »
IIRC Igor Burger last IC LA46 WC plane before he went electric was canted that way... and like most of his stuff, it appears to have taken him far. Not sure if it was published but Igor likes to share, he is on this forum, can't hurt to ask.
EricV
Online Christoph Holtermann
« Reply #6 on: April 19, 2017, 06:40:57 AM »
I have built such model for my Enya-61 side exhaust in 2008 and showed some pictures in another forum:
http://www.clstunt.com/htdocs/dc/dcboard.php?az=show_topic&forum=106&topic_id=1660&mesg_id=1660&page=
I don't have plans but the engine bearers (beechwood) are of triangular shape (20mmx20mm). One glued to the fuselage side. It ends at the first firewall to the tank compartment. The other engine bearer goes up to firewall up to the end of the tank compartment. You have to fiddle the tank in but the engine run was good on the plane, no vibration problems. It already has 930 flights on it. With 1° downthrust and 1.5° side thrust it flies extremely well.
Igors Model had a rear mounted LA-46 in it. He bolted the engine directly to the firewall. I remember it well. He built it in our club.
Christoph
« Reply #7 on: April 19, 2017, 06:45:48 AM »
Thanks Guys. It's a jumping off point.  H^^
Online Igor Burger
« Reply #8 on: May 11, 2017, 12:56:52 PM »
... little later, but I am here :- ))
I had 2 such models with LA .46, both mounted the same way, it worked perfectly, model did not have any cowl, it needed little bit thinking to insert the tank, and flexible screw driver for mounting backplate screws. Both had slim carbon pipes from Randy and orriginal OS manifold which put the pipe to center of fuselage. The best placing before conversion was 10th place in Sebnitz. The same model was later converted to electro as Eric wrote and placed 2nd in Landres.
http://www.netax.sk/hexoft/stunt/the_max_ii.htm
its predecessor was almost identical, the only difference was classic linkage.
http://www.netax.sk/hexoft/stunt/the_max.htm
and yes those desks are in Christoph's club ... BTW thanks Christoph for letting me build them there.
Offline pat king
    • PDK LLC
« Reply #9 on: May 11, 2017, 09:03:05 PM »
The Ringmaster Sportster is a built-up fuselage airplane with the engine canted, it is mounted so that the exhaust points down like a profile ship.
Pat
Pat King
Monee, IL
AMA 168941
Online fred cesquim
    • Fred Cesquim Aeromodelos
« Reply #10 on: May 12, 2017, 06:22:25 AM »
if i understood, you´re asking how to mount the engine support to have the muffler on the belly of the plane.
the (poorly) drawn sketch may be helpfull.
you trace center line and engine base on your firewall, then use the intersection point as a reference, make a 45 degree X, and replicate the engine support distance on the 45 degree lines, hope this helps
you may check if 45 degree is too much placing the engine over the newly drawn lines ok?
