  • July 27, 2025, 01:40:29 AM
Author Topic: Which PA for a Legacy ARF? 61 or 51?  (Read 1626 times)
Offline MarcusCordeiro
« on: November 23, 2013, 03:59:13 PM »
People
That's it.
Which should my friend use in this ship?I said 61, but he thinks it could be too much for the ship...
What say you?? I have zippo experience with PAs....
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Offline Matt Colan
Re: Which PA for a Legacy ARF? 61 or 51?
« Reply #1 on: November 23, 2013, 04:14:53 PM »
51 would work, 61 would be better, more power to handle rough conditions. IMHO.
« Reply #2 on: November 23, 2013, 04:18:32 PM »
I have a Legacy with a PA-51 side exhaust.  The engine is an absolute horse!  I also have a rear exhaust PA-61 in my SL-3 which I really like, but I suspect that my 51 is more powerful.  Randy Smith: what say you?
Scott
« Reply #3 on: November 23, 2013, 04:27:07 PM »
Actually the Lagacy is a fairly large ship and a good flier...none on the PA's would be too much for it.
My absolute favorite is the 65 on a Randy Pipe.  Very tunable and easy to use...always a solid run.
There's no significant weight difference between any of the engines mentioned but the 65 is a growler and easier to use.
The 51 is actually very powerful...probably as much as any of the PA's but a little more finicky to prop and tune than the 65.  At least that's been my experience and I've had several of each in airplanes.  If you can...get a 65 and a pipe and you won't be disappointed.
Probably the closet thing to a turnkey stunt setup available.
Offline Mike Scholtes
« Reply #4 on: November 23, 2013, 06:09:48 PM »
Considering that David Fitzgerald runs a PA75 in his Thundergazer, which is smaller than the Legacy, a PA61 on pipe is not too much engine. Controllable power, not horsepower, is the goal.
My own Legacy is E-powered, but I have a Brodak Legacy kit (unbuilt) and a PA61 on pipe that will go into it. Here in California the larger PAs are more popular, especially the PA65 if you can get your hands on one.
Offline Allen Brickhaus
  • ACE
« Reply #5 on: November 23, 2013, 07:01:34 PM »
I would prefer the PA .61
« Reply #6 on: November 23, 2013, 08:17:41 PM »
People
That's it.
Marcus
Hi Marcus
Either will work very well, I use the 51 in my Katana, it is very easy to setup, just as the 61 is
So just take you pick
« Reply #7 on: November 24, 2013, 02:57:56 AM »
Thank you so much people.
Now, regarding props, what dia and pitch?
3 blade or 2 blade?
Sorry so many questions...
Thanks again for the help...
Marcus
Aces High!
« Reply #8 on: November 24, 2013, 12:39:08 PM »
3 blade or 2 blade?
Marcus
Should you find them the Bolly or Magic  13 x 4.25 2 blade   or  12.25 x 4.25  2 blade work on both
The Bolly or Magic 12 inch x 4.5 3 blades work well on both also, If you have a Lee or eather 13 inch 2 blade  or 12 inch  3 blade  they can also work
« Reply #9 on: November 24, 2013, 05:17:15 PM »
Thanks Randy!
Marcus
Aces High!
  • ACE
« Reply #10 on: November 25, 2013, 05:45:21 AM »
Thank you Randy.
