General control line discussion => Open Forum => Topic started by: MarcusCordeiro on November 23, 2013, 03:59:13 PM
People
That's it.
Which should my friend use in this ship?I said 61, but he thinks it could be too much for the ship...
What say you?? I have zippo experience with PAs....
Marcus
51 would work, 61 would be better, more power to handle rough conditions. IMHO.
I have a Legacy with a PA-51 side exhaust. The engine is an absolute horse! I also have a rear exhaust PA-61 in my SL-3 which I really like, but I suspect that my 51 is more powerful. Randy Smith: what say you?
Scott
Actually the Lagacy is a fairly large ship and a good flier...none on the PA's would be too much for it.
My absolute favorite is the 65 on a Randy Pipe. Very tunable and easy to use...always a solid run.
There's no significant weight difference between any of the engines mentioned but the 65 is a growler and easier to use.
The 51 is actually very powerful...probably as much as any of the PA's but a little more finicky to prop and tune than the 65. At least that's been my experience and I've had several of each in airplanes. If you can...get a 65 and a pipe and you won't be disappointed.
Probably the closet thing to a turnkey stunt setup available.
Considering that David Fitzgerald runs a PA75 in his Thundergazer, which is smaller than the Legacy, a PA61 on pipe is not too much engine. Controllable power, not horsepower, is the goal.
My own Legacy is E-powered, but I have a Brodak Legacy kit (unbuilt) and a PA61 on pipe that will go into it. Here in California the larger PAs are more popular, especially the PA65 if you can get your hands on one.
I would prefer the PA .61
People
That's it.
Marcus
Hi Marcus
Either will work very well, I use the 51 in my Katana, it is very easy to setup, just as the 61 is
So just take you pick
Thank you so much people.
Now, regarding props, what dia and pitch?
3 blade or 2 blade?
Sorry so many questions...
Thanks again for the help...
Marcus
3 blade or 2 blade?
Marcus
Should you find them the Bolly or Magic 13 x 4.25 2 blade or 12.25 x 4.25 2 blade work on both
The Bolly or Magic 12 inch x 4.5 3 blades work well on both also, If you have a Lee or eather 13 inch 2 blade or 12 inch 3 blade they can also work
Thanks Randy!
Marcus
Thank you Randy.
