  • June 18, 2025, 03:15:43 AM
Author Topic: Setup for PathFinder?  (Read 1010 times)
« on: November 24, 2024, 08:40:33 PM »
I’m considering building a Pathfinder and need a little help figuring out the correct electronics.
I have in my inventory a AXI 2826/10 and a 45 AMP Rebel ESC looking to use a 4S 3000m LiPo.
Will this work or do I need to maybe do a BA 3520/790kv and 5s 2800m?
I definitely don’t wanna be underpowered.
I don’t know the KV on the AXI cause it got scratched off. ☹️
It was on another large profile plane I built in 2013.
Any input would be appreciated.
Re: Setup for PathFinder?
« Reply #1 on: November 24, 2024, 08:58:51 PM »
What's the wing area? Pathfinders' not real big is it? Sub 600, I think you'll be fine with the AXI.
« Reply #2 on: November 24, 2024, 10:44:47 PM »
I agree, the 2826 is more than enough to pull a Pathfinder.  Profile or Full body?  I might go with a 35xx for nose weight.
Offline Crist Rigotti
« Reply #3 on: November 24, 2024, 10:59:12 PM »
WA is like 610 or 630
« Reply #4 on: November 25, 2024, 12:02:54 AM »
Crist was on the money: 620 sq. inches.  The IC ones I've seen built pretty light.
« Reply #5 on: November 25, 2024, 05:53:56 AM »
It’s a profile.
What about the battery? 4s or 5s?
Offline Dave Rigotti
« Reply #6 on: November 25, 2024, 07:27:19 AM »
My PointsFinder is very much based on the PathFinder.  I use a Cobra 3515 Kv740 motor. Castle Talon 35 ESC, Hubin FM9 timer and a 5S 2800 TP lipo.
620 square inches at 54oz ready to launch.
I have since "upgraded" to a 6s Li-ion pack due to poor quality TP batteries I have experienced.  No change in motor.
Dave Rigotti
AMA 66859
Chesterland, Ohio
« Reply #7 on: November 25, 2024, 07:40:09 AM »
Thanks Dave. Good to know.
What issue did you have with the TP batteries?
Nice looking model 👍🏼
