After discussing the aerodynamics of big Jim's Lj with Jose madesto i came to the conclusion that if i can add a little more drag to the air craft itself it wont ''dart'' through the maneuvers like it does.
you don't have to move the handle to turn the plane you just have to think about moving the handle and this plane is inverted!!!
Steve,
I am not sure where my earlier post went but I will repost it here.
What you are describing is almost certainly caused by:
1.) Too much handle spacing
2.) Too far rearward a C of G
3.) Improper control throw ratios (less likely)
4.) Too much flap
It would help if you would tell us what your handle spacing is? How far ahead or behind the plans drawn CG is yours? How far ahead or behind the spar is your CG? Have you actually measured to ensure that you have the correct control ratios?
You will not solve this issue by attaching wheelpants.
Kim.
