  • July 07, 2025, 11:41:33 AM
Author Topic: What is this engine  (Read 1810 times)
Offline Will Davis
What is this engine
« on: November 27, 2014, 08:31:37 AM »
Does anyone know what engine this is
Will Davis
"Carolina Gang"
Offline Bill Morell
Re: What is this engine
« Reply #1 on: November 27, 2014, 08:36:45 AM »
Atwood Champion with the spoked head.
Bill Morell
Vietnam 72-73
Offline Will Davis
« Reply #2 on: November 27, 2014, 09:23:40 AM »
Bill,
Thanks for the info,  David smith has the engine from family friend, have entire ign setup, coils, battery , etc, even extra.  Piston cyl, head and flywheel , he also has extra backplate, that has no intake,
I guess it was some type of 2  speed  setup
Will Davis
"Carolina Gang"
« Reply #3 on: November 27, 2014, 12:39:36 PM »
Some features look somewhat like Atwood, but not a "Champion".  This one would be much earlier.
Don't try to run it without plugging the unused crankshaft intake
Offline Will Davis
« Reply #4 on: November 27, 2014, 02:12:11 PM »
Thanks for the help and good advice, I will plug the lower venturi, without damaging the case, compression is very good, , engine will be checked out , , plan is  to bench run only right now, just enough to get a video back to he original owner, .
If we cannot get the ignition to function  properly , what would be a recommendation  to get  engine running  on glow fuel , or  is it not capable  of handling the glow fuel.
Will Davis
"Carolina Gang"
Offline Bill Mohrbacher
« Reply #5 on: November 27, 2014, 02:57:08 PM »
It looks much like an 1940 Atwood Blue Crown Champion 60, the father of the Atwood Champions.  It was a race car or marine engine.  I wouldn't run it and I sure wouldn't run it on glow.  There aren't many of these around
Offline rustler
« Reply #6 on: November 28, 2014, 01:33:59 PM »
If you run it, why not run it on both carbs. as was originally intended?
Ian Russell.
