  • July 19, 2025, 01:59:25 AM
Author Topic: what do ...........  (Read 1450 times)
Offline Bootlegger
what do ...........
« on: November 18, 2009, 12:44:47 PM »
     You use to thin finishing epoxy to brush into the engine and tank compartments, and how much do you thin it??
  Equal parts like 1,1,1 or do you do it another way?
   I have already put one coat in these areas and want to put in another.
  I know also that using a hair dryer wil make it flow better..
   What say ya'll ????????   T I A,
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Les McDonald
  • " The Jelly Man"
Re: what do ...........
« Reply #1 on: November 18, 2009, 01:27:25 PM »
A little bit of alcohol from the medicine cabinet.
                                              Les McDonald
I see people my age out there climbing mountains and zip lining and here I am feeling good about myself because I got my leg through my underwear without losing my balance
Offline Bill Hodges
« Reply #2 on: November 18, 2009, 01:36:04 PM »
What Les said and it doesn't take much.
Bill Hodges
Bill Hodges
AMA 12450
Offline Bootlegger
« Reply #3 on: November 19, 2009, 08:20:02 AM »
 Thanks guy's I appreciate the info...... H^^
Gil Causey
AMA# 6964
posthole_digger
« Reply #4 on: November 19, 2009, 09:44:54 AM »
Be careful. Medicine-cabinet alcohol can have a lot of water in it which will affect the epoxy. I use denatured alcohol.
Offline Clancy Arnold
« Reply #5 on: November 19, 2009, 11:45:46 AM »
Correct!!!
Isopropyl Alcohol (91% to 97% Alcohol) not Rubbing Alcohol (70% Alcohol)
Clancy
Clancy Arnold
U/Tronics Control
Offline W.D. Roland
« Reply #6 on: November 19, 2009, 07:38:46 PM »
Have used both types of alcohol and also lacquer thinner.
When I had it I used Hobby poxy thinner.
No problems with any of it.
If it is going on foam or plastic use only the alcohols.
What ever you use you may think it will never cure, It will! just leave it alone till it does.
David
David Roland
51336
Offline Bootlegger
« Reply #7 on: November 20, 2009, 05:48:34 AM »
         #^  I thinned it slightly with the Denatured alcohol and left it overnight, came out very well..  Thanks for all the suggestions... D>K
Gil Causey
AMA# 6964
« Reply #8 on: November 20, 2009, 07:02:40 AM »
I just use the heat gun with finishing epoxy and skip the liquid thinner.  Depending on the epoxy you have, heat alone gets it pretty thin.  You can wipe off the excess with a paper towel.  Of course you need some finesse in the heating department, you don't wanna make it gas off.
If you must use liquid thinner, forget the drug store and buy a gallon of denatured alchohol from Tony's or use a bit of Everclear from the liquor cabinet.  If Fat Al and his gang get the upper hand, you'll be able to siphon off a little from the fuel tank of your Smart Car.
