  • July 03, 2025, 03:24:27 PM
Author Topic: Rear Exhaust Info needed  (Read 2132 times)
Offline Scott B. Riese
  • Just a student of stunt
« on: October 27, 2009, 12:59:08 PM »
Good Day everyone!!
My new project this winter will be a Rear Exhaust Set up 40VF. I need to know "IF" Anyone has ever had any problems with Mounting holes for the muffler elongating the engine flange, and/ or, any welds breaking on the muffler it's self? These are my concerns.
Scott(learn as we go)Riese
Scott Riese
Portland, Oregon
AMA 528301
Online Howard Rush
Re: Rear Exhaust Info needed
« Reply #1 on: October 27, 2009, 01:06:52 PM »
I never had either of those problems.  You'll like that engine.
Howard (used VFs for a long time) Rush
« Reply #2 on: October 27, 2009, 02:40:10 PM »
Scott,
I've never tried one with a muffler. With a header, I just use some parts sealer between the header and the gasket (both sides) and snug up the bolts.
Offline WhittleN
« Reply #3 on: October 28, 2009, 07:58:02 AM »
Scott
I was looking at my VF 40 the other night and did notice that the mounting ears are not very robust looking.  I think we are getting away with mounting the header and supporting the pipe properly but a muffler may be another story.  The extra weight and add to that an exhaust extension could present a problem.  I would suggest supporting the muffler with some kind of rubber mount or isolating the muffler with a coupler at the exhaust exit.  I have been down that road with the Stalker 76 and 51.
Norm Whittle
Online Howard Rush
« Reply #4 on: October 28, 2009, 11:33:49 PM »
Speaking of pipes, Norm, your mods to the ES Composites pipe work great.
Offline WhittleN
« Reply #5 on: October 29, 2009, 06:26:38 AM »
Thanks Howard
I am presently running a VF 40 in my Sultan and it runs just fabulous.  The entire set-up per Brett Buck/Paul Walker NO deviations.
Norm Whittle
« Reply #6 on: October 29, 2009, 10:53:52 AM »
Norm,
That was my experience. It's a turnkey setup. I set mine up just as Paul and Brett told me to and it ran great. I couldn't have been happier. Depending on how this new plane comes out, that setup may end up in it.
Offline Dan Labine
« Reply #7 on: October 29, 2009, 07:20:30 PM »
I just purchased one. Whats the setup that you are describing?
Dan
MAAC 14300
« Reply #8 on: October 29, 2009, 09:48:36 PM »
Thanks Howard
Norm Whittle
   I would hasten to point out that the setup is actually Paul's - my only association with it was to post it a lot of times on the internet. In fact, I think it's identical to what Paul provided in the Impact article in 1991.
    I ran a very different system (with some success) for many years, but I have since come to the conclusion that Paul's is better in most cases.
Offline frank williams
« Reply #9 on: October 30, 2009, 08:10:21 AM »
Scott,
My experience was that the VF40 was that it was the smoothest running stunt motor I ever run.  Little to no vibration at all.
Norm,
What's your mod to the ES pipe?
Frank
Offline WhittleN
« Reply #10 on: October 30, 2009, 05:37:24 PM »
Dan
Search VF 40 in the stunt forums.  Brett has posted it numerous times.  I am presently running the small venturi as my VF 40 is 25 years old but still new.
Frank
I worked with Ed from ES to move the baffles and hole sizes.  If you want the drawing that I sent Howard let me know.  I don't know if Howard made the mods or ordered one from ES.
« Reply #11 on: October 30, 2009, 09:41:25 PM »
Norm,
do you have contact information for ES?
Online Howard Rush
« Reply #12 on: October 30, 2009, 11:57:39 PM »
http://www.escomposites.com/ , but I forget which one to get.  Were I to do it again, I'd try to get just the outside parts unassembled and put in my own baffles per Norm's spec.
