  • July 17, 2025, 07:04:11 AM
Author Topic: Veco 19 v.s. Fox 35  (Read 1928 times)
Offline Ryan Taylor
Veco 19 v.s. Fox 35
« on: January 03, 2007, 06:17:29 PM »
Just a quick question, I am thinking about switching the engines on my flight streak, and I was wondering what is more fuel efficient? The Veco 19 or the Fox 35?
Prop Buster
Ryan Taylor
Offline peabody
Re: Veco 19 v.s. Fox 35
« Reply #1 on: January 03, 2007, 06:23:50 PM »
I believe that the Veco is a great choice for the plane....
Offline Marvin Denny
« Reply #2 on: January 03, 2007, 06:45:10 PM »
  The Veco 19 will be more fuel efficient, but may be a little wimpy for the Streak. That is unless the streak is pretty light.
  Bigiron
marvin Denny  AMA  499
Offline peabody
« Reply #3 on: January 03, 2007, 07:18:17 PM »
Marv....
Help me out here...
Is the Flite Streak ARF the same as the kitted version that we all know and love?
I fly my ARF with a Norvel 15 and it works okay, though not a 100 mph deal like you are fond of....
Offline Steve Holt
« Reply #4 on: January 03, 2007, 08:13:40 PM »
What model is your Veco 19?  The ball bearing series is a great engine and has lots of power for the ARF Streak.  It should do the pattern easily on 3 oz.
The ARF Streak is similar to the kit, but has a longer tail moment.  It is light and flys very well.  Much better covering than the Brodak ARF's but the bellcrank is not as good.
Offline Russell Shaffer
« Reply #5 on: January 03, 2007, 08:34:29 PM »
How do you think a 70's Fox 19 would do on a Streak?  It runs very well, but I don't have any way to compare it to newer stuff.  Thanks.
Russell Shaffer
Klamath Falls, Oregon
Offline Chris Brainard
« Reply #6 on: January 03, 2007, 11:54:36 PM »
My 30 oz. Fancy Pants has been flown with a Brodak .40, O.S. Max .35 S, O.S. .25 FP, O.S. .25 LA and Veco .19 B.B. I like it with the Veco the best. One advantage of using the Veco .19 instead of a Fox .35 on the Flite Streak is that you can use .012" diameter lines. This proved to be a big advantage on my Fancy Pants. My experience with fairly lightweight models, is that the weight of .015" diameter lines really hurts their performance, even with a bigger engine. I was able to reduce tip weight with the smaller diameter lines and the reduced drag of the lines reduced yawing which improved the square maneuvers.
Chris
« Reply #7 on: January 03, 2007, 11:57:02 PM »
Hi Paul,
If it is the BB Veco 19, and it's in good shape, it is more than enough for the Flite Streak.  y1
Bill <><
Offline Harleyman
  • ACE
    • Circle Masters
« Reply #8 on: January 04, 2007, 08:47:58 PM »
Ryan,
The Veco 19 will be more fuel efficient.
I fly my ARF Streak with an Enya 19 that really hauls it around without a muffler. I know nothing about a Veco 19 but if it's anything like the Enya, it should do fine without the muffler (extra weight).  I fly my Enya in a nice wet two cycle.
Is the P&L all steel construction? My old Enya is, so if the Veco is the same, make sure you use the same type of fuel you'd run in a Fox 35.
My guess is, it should work well with your ARF Streak, because it is pretty light.
 o2oP
« Last Edit: January 05, 2007, 09:01:10 AM by Harleyman »
Chris Sterner
AMA 1825
EAA 1429853
https://circlemasters.com
