  • July 19, 2025, 12:56:19 PM
Author Topic: Uniflow tank set up options for control line McCoy .35  (Read 1268 times)
Offline Ronald Eshleman
« on: October 02, 2017, 01:11:56 PM »
How do I set up a uniflow tank in a built up fuselage control line plane with a McCoy 35 engine.
Offline Dennis Nunes
Re: Uniflow tank set up options for control line McCoy .35
« Reply #1 on: October 02, 2017, 03:14:55 PM »
Ronald,
You might look at the following link: https://stunthanger.com/smf/engine-set-up-tips/st-v60-has-to-be-set-very-rich-then-runs-lean/msg498098/#msg498098
This is what I used for a ST v60 with muffler pressure attached to the uniflow vent. It should work with no muffler pressure if you so choose.
Dennis
« Reply #2 on: October 02, 2017, 06:56:28 PM »
I have flown McCoy 35's and 40's and what always worked best for me was a uniflow vent tank with the unilflow blocked and the standard vent open. In other words a standard tank. But it is always good to have a uniflow tank so you have options. They do lean a little all the way through the flight, but it is very slight and helps when you get to the clover.
Offline Lyle Spiegel
« Reply #3 on: October 03, 2017, 05:06:47 AM »
please explain why uniflow w/o muffler pressure setup for McCoy would be any different than Fox35 or anyother stunt installation?
Lyle Spiegel AMA 19775
« Reply #4 on: October 04, 2017, 04:13:27 PM »
The McCoy's seem to not change rpm much from the beginning of the tank to the end on non uniflow where Foxes always leaned out quite a bit toward the end of the tank. And, the McCoy's seem to richen up on uniflow. I have run them both ways, and the McCoy's seem to run better on a standard tank set up. At least on the planes I have them on which are all profiles. Magicians, and Ringmasters. In a full fuse they may run better uniflow.
