  • July 21, 2025, 11:21:46 PM
Author Topic: Twister weight  (Read 900 times)
Dwayne
Twister weight
« on: June 30, 2011, 06:09:15 PM »
Hey all I just electrified my Twister weight is 42 oz. and its a bit nose heavy so if I hve to add a couple oz. of weight to the tail is 44 0z. going to be much?
Dwayne
Offline Dennis Moritz
Re: Twister weight
« Reply #1 on: June 30, 2011, 07:38:55 PM »
Sorry. See it's electric. If you have enough power it should fly all right if well trimmed. I had a Twister at that weight powered by an FP40. An excellent flier when all the adjustable stuff was in harmony. A dog before that. Try to shift the batteries back to handle the nose heavy condition. Folks have mounted batteries in the wing. Dunno if that's possible now.
Re: Twister weight
« Reply #2 on: June 30, 2011, 08:20:44 PM »
Mine weighs 47 oz, but it's Fancherized, big stab/elev., and is IC powered. It flies fairly well, but hurts the suicide corners. Try to avoid adding weight by moving what you've got. The control ratio will need to be 1:1 for flap/elev.
D>K Steve
Dwayne
Re: Twister weight
« Reply #3 on: July 01, 2011, 04:52:06 AM »
Thanks guys I'll try shifting the batt for now and see if I can find a lighter one.
Re: Twister weight
« Reply #4 on: July 01, 2011, 05:19:35 AM »
Good Idea. Much better to add lightness . ;D Could look to see whats involved in shortening nose , as option .
Plan C.G. position is usual a guide , not infalible . a notch nose heavy might get it less jumpy . Ordinarilly youd
pull it back as you got used to it. When it acted snotty youd know to back of to last position or two.Establish
a working range youre happy with . Not as far back in bumpy air .
