  • July 19, 2025, 01:48:48 AM
Author Topic: Twister Rebuild  (Read 1368 times)
Offline James Holford
Twister Rebuild
« on: September 09, 2018, 04:46:09 PM »
Finally got off my butt and got to work on the Twister since the crash due to my negligence.
 Superfilled all gashes and dings..redone some fillets..recovered the lower inboard wing. Dressed it up with some vinyl graphics.
 All thats left is repaint a few spots.. shoot some 2K clear. Mount tank and motor. And go fly. But will have to wait due to rain.
Really wish I would have done this right after it crashed so I could of had it in Dallas last weekend.  Watch out Tulsa!!!
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Offline DanielGelinas
Re: Twister Rebuild
« Reply #1 on: September 09, 2018, 04:56:16 PM »
I like your fleur de lys. Are you acadian?
Nice rebuild!
Dan
Re: Twister Rebuild
« Reply #2 on: September 09, 2018, 04:57:13 PM »
Nice rebuild!
Dan
Thanks.
Im Cajun
Jamie Holford
Lafayette, La
AMA #1126767
Offline Tom Luciano
Re: Twister Rebuild
« Reply #3 on: September 09, 2018, 06:32:47 PM »
Nice job, Jamie! y1
AMA 13001
Re: Twister Rebuild
« Reply #4 on: September 10, 2018, 09:46:25 AM »
I like the graphics. H^^
Offline Myron Firmin
Re: Twister Rebuild
« Reply #5 on: September 14, 2018, 04:02:54 PM »
Nice looking plane . . . lignes serrées!
Myron Firmin
Definition: Work Bench, a place to stack stuff, so you can build on the card table.
www.facebook.com/ringmastersflyingclub
Re: Twister Rebuild
« Reply #6 on: September 14, 2018, 07:29:19 PM »
Nice looking plane . . . lignes serr�es!
Jamie Holford
Lafayette, La
AMA #1126767
Offline Tim Chenevert
Re: Twister Rebuild
« Reply #7 on: September 15, 2018, 06:05:02 PM »
That Twister looks great!!!! Tim
AMA 179681
Re: Twister Rebuild
« Reply #8 on: September 15, 2018, 07:00:53 PM »
Thanks. Had some issues with the can of 2k clear tho.. it was same can I used to clear it when I first finished it. Stored in fridge til I used it the other day... did go on so well and now it has a "grit" to it... it would be bad of the entire fuselage looked that way but ut bugs me. Bought a new can and will lightly sand the roughness and respray. But it wasnt meant to be a beauty queen anyways lol.
 As long as it flies good as it did before I can careless how it looks lol.
Jamie Holford
Lafayette, La
AMA #1126767
Offline Tom Luciano
Re: Twister Rebuild
« Reply #9 on: September 15, 2018, 07:20:27 PM »
Jamie,
 Looks good from here!
  I had a similar issue. I was able to sand it out with 1200 grit and buff. I would try that before cracking open a new can and adding more weight.
Tom
AMA 13001
Re: Twister Rebuild
« Reply #10 on: September 15, 2018, 07:23:42 PM »
Jamie,
Tom
I hit a spot under the fuselage lightly with 1000 grit and it knocked down that roughness a good bit.
 The first time I shot the 2k clear I followed the method posted here and it worked GREATTTT. Smooth as glass..  My guess is the can I used was no more good or perhaps "crystalized" from the cold temps but Im certain Im wrong about that. Id lean the shelf life went out the window.  But I will try sanding it first just to see.
Jamie Holford
Lafayette, La
AMA #1126767
Offline Tom Luciano
Re: Twister Rebuild
« Reply #11 on: September 15, 2018, 08:26:50 PM »
I've had success using a month after keeping in freezer. Needs to be warm prior to spraying or orange peel happens. I had sprayed 6 months after opening and it came out rough as a road. Knocked it off with sandpaper and polish with no I'll affects. Except a boat load of cursing and sore elbow.
Tom
AMA 13001
Re: Twister Rebuild
« Reply #12 on: September 15, 2018, 08:29:04 PM »
Tom
Haha which Im sure I will be doing alot of!!
Jamie Holford
Lafayette, La
AMA #1126767
