  • July 16, 2025, 01:39:35 PM
Author Topic: Tutor II ARF-This time missing Fus.  (Read 1469 times)
Offline Leester
« on: October 09, 2006, 06:00:29 PM »
FYI: Tower has a Tutor II ARF in scratch and dent for 32.00 but it is missing the wing. You must be a super saver member. They also have a LA 40 (R/C) for 54.00 missing instruction manual.
« Last Edit: October 19, 2006, 02:26:56 PM by Leester »
Leester
ama 830538
Offline Leester
Re: Tutor II ARF-This time missing Fus.
« Reply #1 on: October 19, 2006, 02:29:46 PM »
OK Ty this time they have one missing the fus. for 32.00 so I bought it might be more don't know. I can cut a new profile fusalage but out of curriosity what other fusalage would go good with the Tutor II wing ???
Leester
ama 830538
« Reply #2 on: October 19, 2006, 03:26:34 PM »
Hi Lee,
Take the Tutor II moments and layout, draw them on a sheet of paper, then draw your own "outline" to it!  You will have "designed" your own plane then!   That's exactly what so many did back in the '60s with the Nobler. y1
Bill <><
« Reply #3 on: October 22, 2006, 01:00:38 PM »
As I predicted! Tony Bagley got the fuselage, to replace the one in his #2 Tooter Too, which was badly warped. Make a new fuselage. Raise the wing about 5/8" to correct the vertical CG problem. :D Steve
