General control line discussion => Open Forum => Topic started by: Leester on October 09, 2006, 06:00:29 PM
FYI: Tower has a Tutor II ARF in scratch and dent for 32.00 but it is missing the wing. You must be a super saver member. They also have a LA 40 (R/C) for 54.00 missing instruction manual.
OK Ty this time they have one missing the fus. for 32.00 so I bought it might be more don't know. I can cut a new profile fusalage but out of curriosity what other fusalage would go good with the Tutor II wing ???
Hi Lee,
Take the Tutor II moments and layout, draw them on a sheet of paper, then draw your own "outline" to it! You will have "designed" your own plane then! That's exactly what so many did back in the '60s with the Nobler. y1
Bill <><
As I predicted! Tony Bagley got the fuselage, to replace the one in his #2 Tooter Too, which was badly warped. Make a new fuselage. Raise the wing about 5/8" to correct the vertical CG problem. :D Steve
