  • June 28, 2025, 05:13:46 PM
Author Topic: Tulsa Gluedobber Contest  (Read 6086 times)
Offline Elwyn Aud
    • Inferalandings Photo Page
« on: September 11, 2017, 06:31:54 PM »
September 23 and 24.
http://www.tulsacl.com/Events.html
We will have a huge raffle this year and a lot of stuff for sale for super cheap prices.
Offline De Hill
Re: Tulsa Gluedobber Contest
« Reply #1 on: September 12, 2017, 01:20:07 PM »
We will also have a huge sale of Engines, Airplanes and Accessories for a club member who is downsizing.
They will be cheap, as we do wish to move them.
De Hill
Offline Allan Perret
  • Proverbs
« Reply #2 on: September 12, 2017, 03:10:07 PM »
Are any of those RedHead McCoys complete ?  What are sizes and prices ?
Allan Perret
AMA 302406
Slidell, Louisiana
Offline De Hill
« Reply #3 on: September 12, 2017, 04:25:43 PM »
Yes!
We have .35 and .40 Redheads. (complete)
I
We still have to look at the engines to price them.
Do you know a guy from Slidell named Mickey Brignac?
« Last Edit: September 12, 2017, 04:52:49 PM by De Hill »
De Hill
  • Proverbs
« Reply #4 on: September 13, 2017, 06:37:24 AM »
Yes!
I
Don't know Mickey, is he a c/l flyer?
Does the 40 red head have same case as the 35 ?
Allan Perret
AMA 302406
Slidell, Louisiana
Offline De Hill
« Reply #5 on: September 13, 2017, 07:04:49 AM »
I'll have to  go out to the field tomorrow and look at the engines; they haven't been priced yet. Then I'll send you a private message about the prices.
Mickey was a student of mine back in the late 1960's.
De Hill
« Reply #6 on: September 15, 2017, 06:43:27 AM »
Just to answer the question -the .35 and .40 are interchangeable in an airplane and I have to look for the number to know which I have in my hand.  Pretty sure the .29 is too though I haven't thought to try it.  You wouldn't tell much difference running them though the .40s always seemed to be fit a little better and so seemed more consistent one engine to another.  The center plug .35s all seemed as good.  Most all the .19s through the Series .21s seemed to be fit way too loose.  IF you can get them started they run well but they are definitely in a smaller case.
  • Proverbs
« Reply #7 on: September 21, 2017, 10:31:24 AM »
So whats the difference between the center plug and the slant plug, anything other than the head.  Seems like the ones I bought as a teenager for $5.95 were all the slant plug.
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #8 on: September 21, 2017, 12:30:01 PM »
I believe the difference was the involvement of Dick McCoy. The center vertical plug engines were made under his ownership and supervision to good tolerances.  He sold ownership to the Duromatic corporation who slanted the plug I presume to distinguish the change.  They chose looser mass production standards and fits which led to slightly inferior engines though they can run very well if they will start for you.  The 'Custom' series came with another change in ownership with even worse results.  Finally Testor corporation took over with the original design numbers internally but ditched the cintered iron piston and went with an aluminum piston and Dykes ring along with an entirely new case and called them Series 21.  These are actually very good and long lasting Stunt engines except for the .19s which suffered the poor dimensional fits that all the .19s did.
Kevin and I should arrive at Dobberville around noon tomorrow.
Offline De Hill
« Reply #9 on: September 21, 2017, 02:48:06 PM »
Many years ago, Wild Bill Netzeband told me  That He was working at Testor's when the series 21 engine was designed. He said that he designed the innards ( a slight redesign of the Red Head McCoys), and the people running Testor's at that time hired an industrial designer to do the outside of the engine. It was supposed to look whoopy, and no consideration was given to weight. The result was the Series 21 McCoy. It ran ok, but was heavier than it should have been.
A lot of Lightning Bolt McCoy Red Heads have been modified with Series 21 Pistons. The Lightning Bolt Redhead cylinders are used because they have windows on the ports. Without the ports, the Dyke ring would get stuck in the wide open ports on the earlier Redheads.
De Hill
Offline James Holford
« Reply #10 on: September 21, 2017, 03:25:05 PM »
Wish i were goin.....i like cheap n raffles
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Offline De Hill
« Reply #11 on: September 21, 2017, 03:44:49 PM »
I went out to the field today and found that we had contestants who had arrived yesterday,  John Blanchard, and Brent and Jackie Rogillio  from Louisiana were out at the field trimming airplanes with Joe Gilbert. Tom Martin showed up with a whole lotta airplane stuff. He is selling out , and the stuff is cheap! Before I left, Joe told me that he got phone calls from Dale and Linda Gleason, and Don and Sheila Cranfill. they were getting close to the field.
I left after 2pm, and passed Elwyn Aud as He arrived.
De Hill
Offline Elwyn Aud
What did you do on the last day of summer?
« Reply #12 on: September 21, 2017, 07:06:04 PM »
Hot afternoon. The air conditioned clubhouse was wonderful.
« Reply #13 on: September 21, 2017, 08:25:22 PM »
Love his T-rex. Sounds good too
Jamie Holford
Lafayette, La
AMA #1126767
« Reply #14 on: September 22, 2017, 10:56:30 AM »
As I will not make it again this year I have been looking at the Web Cam.   So far nobody flying on the main circle but a half dozen vehicles sitting there.  Also shows 85+ degrees and 14+ mph wind.  Any way you all have fun. H^^
« Reply #15 on: September 22, 2017, 11:06:02 AM »
Doc it's pretty windy here.  They are going to bring dinner out here to the field tonight so everybody can hang out here when the wind lays down.  So far aside from the local guys Dale Gleason,  Don Cranfield,  Frank McMillin,  Bob Brookins, Lou Woolard and ourselves are at the field.
« Reply #16 on: September 22, 2017, 02:15:24 PM »
The wind is getting worse here.  The forecast looks like it may be flyable the last hour before dark.  New arrivals are Richard Oliver,  Joe Bowman, John Hill and Jim Lee.  A lot of BS flying here.
« Reply #17 on: September 22, 2017, 03:48:20 PM »
Just checked the WEB site and it shows almost 90 degrees and 15 mph winds.   Tell every body the old DOC says hi. D>K
« Reply #18 on: September 22, 2017, 03:57:46 PM »
The wind is not letting up yet but Joe Gilbert is putting up a test run on one of Dale Gleason's old airplanes.
Offline Elwyn Aud
« Reply #19 on: September 22, 2017, 05:46:00 PM »
A few pics from Friday. Would have been more but I think I left a memory card at the field(inside the camera!).
« Reply #20 on: September 22, 2017, 06:38:36 PM »
Fast and Furious!  After a pile of nachos and deserts for dinner the wind broke at 6:30 and we had one hour of Stunt weather.  Everybody ran for the planes to get one flight for the day.
« Reply #21 on: September 22, 2017, 06:43:05 PM »
Excellent pics!. Hope tomorow provides better winds!
Jamie Holford
Lafayette, La
AMA #1126767
« Reply #22 on: September 22, 2017, 07:21:55 PM »
Glad to see you guys are having what seems to be a good turnout for your contest.  The third weekend after Labor Day has been the traditional date for the Carl Marchenke Memorial contest here in Tucson and is again this year as last year and so forth.
Turnout this year and last year has been very poor and it would seem that the contest held there on those traditional dates could be part of the problem.
It would seem that we could do a little better job of coordinating contest dates in the Southwest area so as more could attend both contests.  I'm sure after this the Cholla Choppers will be rethinking contest dates even though this has been a traditional contest for this club for approximately 30 years or so!
Best of luck with the contest!
PS:  We haven't had much luck with wind all this week and today either!
« Reply #23 on: September 23, 2017, 11:06:57 AM »
The weather cooperated today and the flying goes on.  Elwyn has been busy on the camera and will a lot of great shots later but here are a few as the day progresses:
« Reply #24 on: September 23, 2017, 11:08:13 AM »
Here's Richard Oliver practicing for tomorrow
« Reply #25 on: September 23, 2017, 11:09:04 AM »
« Reply #26 on: September 23, 2017, 11:09:51 AM »
« Reply #27 on: September 23, 2017, 11:10:28 AM »
« Reply #28 on: September 23, 2017, 11:12:20 AM »
« Reply #29 on: September 23, 2017, 11:12:59 AM »
« Reply #30 on: September 23, 2017, 11:24:49 AM »
Classic and Old Time are finished flying .  Here is those scores:
« Reply #31 on: September 23, 2017, 11:25:25 AM »
  • Proverbs
« Reply #32 on: September 23, 2017, 11:34:37 AM »
Thanks for the pics Dave .
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #33 on: September 23, 2017, 11:55:10 AM »
The web site shows stunt heaven but every body must be eating.  Will check again later as have been helping/hindering the wife with new dish washer.   She doesn't like the way I do dishes and I don't break any. D>K
« Reply #34 on: September 23, 2017, 12:05:17 PM »
Finished the profile and yes it's lunch- soup and sandwiches at the field.  Here's the scoreboard.  The wind picked up some and is at the go-no go point.  We'll likely try to get some practice in then I think it's the Mexican restaurant tonight for many of this herd.
« Reply #35 on: September 23, 2017, 12:05:50 PM »
Offline Norm Faith Jr.
« Reply #36 on: September 23, 2017, 02:06:19 PM »
Looks like Joe got the engine run issue cleared up. Way to go Joe.
Norm
Circlepilot   AMA9376
Online Howard Rush
« Reply #37 on: September 23, 2017, 02:33:59 PM »
Please send me results for Stunt News.
« Reply #38 on: September 23, 2017, 03:56:23 PM »
Howard we fly Pampa classes tomorrow and I'll post the scoreboard when done.  Do you need anything else beyond that?
Offline Elwyn Aud
« Reply #39 on: September 23, 2017, 04:34:47 PM »
Glad to see somebody else getting a few photos! Here are a few more from Friday.
Offline Elwyn Aud
« Reply #40 on: September 23, 2017, 04:53:48 PM »
Saturday action.
« Reply #42 on: September 23, 2017, 06:24:31 PM »
Thanks for the pics. Hood pic of Brent and his Mentor!
Jamie Holford
Lafayette, La
AMA #1126767
Offline Matt Colan
« Reply #43 on: September 23, 2017, 07:27:56 PM »
Wish I could've made it this weekend!! Looks like it's been a great time! The FAA gave me a class date for ATC next week and I had to use this time to go see my family in Vermont.
Offline Elwyn Aud
« Reply #44 on: September 23, 2017, 07:55:10 PM »
A few more
Online Brent Williams
« Reply #45 on: September 24, 2017, 01:05:00 AM »
Looks like a great contest.
Who's Pathfinder is this?  Curious about his electric setup.
« Last Edit: September 24, 2017, 05:57:17 AM by Brent Williams »
Offline Andre Ming
« Reply #46 on: September 24, 2017, 06:53:00 AM »
Looks like the 'Dobber's are again hosting a superb contest. I didn't have the available time (vacation days) to be at this event along with the upcoming Combat Legends weekend in October.
Thanks to all that are keeping us updated as it happens. Thanks to Elwyn and all for pictures. There's some great looking planes there again!
« Reply #47 on: September 24, 2017, 11:43:13 AM »
Today's results:
« Reply #48 on: September 24, 2017, 11:44:06 AM »
« Reply #49 on: September 24, 2017, 11:53:42 AM »
Thanks for all the great pictures. Sure miss being there. I am hoping to get off of the Prednisone in a few weeks after almost a year. Hoping my back will get better then. Congrats to Gary Mondry for wining old time.
