  • July 10, 2025, 06:55:30 PM
Author Topic: Sig C/L Parts  (Read 1688 times)
Offline Leester
Sig C/L Parts
« on: November 08, 2006, 10:06:12 AM »
I see on Sigs web site they offer the Mustang stunter foam wing kit and the foam wing core for the Magnum, plus other items for these discontinued kits. Is this something new ? I never noticed these items before.
Leester
ama 830538
Re: Sig C/L Parts
« Reply #1 on: November 08, 2006, 11:35:22 AM »
they have not updated the site....they are not available
Offline Leester
Re: Sig C/L Parts
« Reply #2 on: November 08, 2006, 12:15:43 PM »
Wynn: They have the Primary Force info on the same page it looks like an updated version from previous listings.
Leester
ama 830538
Re: Sig C/L Parts
« Reply #3 on: November 08, 2006, 09:28:08 PM »
pretty sure you will find they do not sell them....they also have a Hexdron add that says it is 50" span......along with the actual hexdrone (061 powered)
cant believe everything you read..
Offline Jim Oliver
Re: Sig C/L Parts
« Reply #4 on: November 08, 2006, 09:42:58 PM »
I called Sig several months ago about the Magnum cores---"no longer available".
Jim
Jim Oliver
AMA 18475
Offline Ken Deboy
    • Silk and Dope
Re: Sig C/L Parts
« Reply #5 on: November 08, 2006, 10:42:30 PM »
Are the Magnum cores available from http://www.clguy.com/ the same as the Sig kit?
cheers,
There is a fine line between "hobby" and "mental illness"
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: Sig C/L Parts
« Reply #6 on: November 09, 2006, 03:55:22 AM »
My understanding is if you build a Magnum even from the kit you don't want to use the SIG cores because they are heavier than what you can get from the aftermarket wing cutters.
Offline Ron King
Re: Sig C/L Parts
« Reply #7 on: November 09, 2006, 06:30:14 AM »
No. Crist's cores are better.  <=
Ron King
AMA AVP District 4
Wannabe Stunt Pilot since 1963
 Amateurs practice until they get it right; Pros practice until they cannot get it wrong.
Re: Sig C/L Parts
« Reply #8 on: November 09, 2006, 11:06:51 PM »
Sir Ron of King is correct (as usual) about Crist's cores being better.  y1
To clarify the answer to your question:  they are the same "size" and airfoil, but cored better and made from better foam.
