General control line discussion => Open Forum => Topic started by: Leester on November 08, 2006, 10:06:12 AM
I see on Sigs web site they offer the Mustang stunter foam wing kit and the foam wing core for the Magnum, plus other items for these discontinued kits. Is this something new ? I never noticed these items before.
they have not updated the site....they are not available
Wynn: They have the Primary Force info on the same page it looks like an updated version from previous listings.
pretty sure you will find they do not sell them....they also have a Hexdron add that says it is 50" span......along with the actual hexdrone (061 powered)
cant believe everything you read..
I called Sig several months ago about the Magnum cores---"no longer available".
Jim
Are the Magnum cores available from http://www.clguy.com/ the same as the Sig kit?
cheers,
My understanding is if you build a Magnum even from the kit you don't want to use the SIG cores because they are heavier than what you can get from the aftermarket wing cutters.
No. Crist's cores are better. <=
Sir Ron of King is correct (as usual) about Crist's cores being better. y1
To clarify the answer to your question: they are the same "size" and airfoil, but cored better and made from better foam.
