  • July 17, 2025, 06:58:21 PM
Author Topic: TT 11x4.5 props  (Read 16405 times)
Offline Rick Bollinger
  • AMA 931589
TT 11x4.5 props
« on: January 05, 2018, 11:44:49 AM »
I have been talking to my contact at TT and I can do a run of the 3530 Cyclone props. The bad news is they are more expensive.
They will be around $5.50 each plus shipping. I need to know how many would commit at this price and how many you want. Just respond here with how many you would want. I suspect after this run there will be no more. As this will be my last time ordering. (I need to order a lot of these to get them)
Also I may be able to get some TT 12.5 x 5.5 if there is a interest. Does anyone have the number of these props? I am not familiar with them.
Rick
Rick Bollinger
AMA 931589
Offline Fredvon4
  • Central Texas
Re: TT 11x4.5 props
« Reply #1 on: January 05, 2018, 12:16:13 PM »
I am ok with the price increase
If still in 6 each packages, like last time, I would like two packages
If singles just 10 each for me
Fred
Fred von Gortler IV
Offline big ron
Re: TT 11x4.5 props
« Reply #2 on: January 05, 2018, 12:48:13 PM »
i would take 6 of each
John Blanchard
Brusly, Louisiana
 AMA 1054488
Online Paul Taylor
Re: TT 11x4.5 props
« Reply #3 on: January 05, 2018, 01:42:38 PM »
I'm in for two 6 packs.
Offline Dane Martin
  • heli pilot BHOR
Re: TT 11x4.5 props
« Reply #4 on: January 05, 2018, 02:09:22 PM »
Two 6 packs. Or if singles, 10 is fine.
Rick_Huff
Re: TT 11x4.5 props
« Reply #5 on: January 05, 2018, 02:30:12 PM »
I'd like 6 of the 11x4.5
I have a 12.5x5.5 and the part number is 3518.
Rick
Offline Lyle Spiegel
Re: TT 11x4.5 props
« Reply #6 on: January 05, 2018, 02:40:36 PM »
I 'm in for two packages of 6,  11x 4.5. Best prop ever used.
Lyle Spiegel AMA 19775
Offline Dave Harmon
  • Tulsa Glue Dobbers C/L and R/C Clubs AMA 5053
Re: TT 11x4.5 props
« Reply #7 on: January 05, 2018, 04:33:06 PM »
I'll buy 12 of the 11x4.5
Offline Walter Hicks
Re: TT 11x4.5 props
« Reply #8 on: January 05, 2018, 06:01:58 PM »
interested in  6 of 12.5x5.5 and 6 of 11x 4.5
« Last Edit: January 06, 2018, 10:49:50 AM by Walter Hicks »
Offline Chris Fretz
Re: TT 11x4.5 props
« Reply #9 on: January 05, 2018, 07:19:53 PM »
I'll try 10 11x4.5 I'll try 6 12.5x5.5 also
« Last Edit: January 06, 2018, 02:29:08 PM by #Liner »
Formerly known as #Liner
AMA 1104207
Advanced
Offline Charles Carter
  • Flying Control Line Stunt
Re: TT 11x4.5 props
« Reply #10 on: January 05, 2018, 07:30:23 PM »
What are these props a good match for engine wise?  40VF or 46VF?
Re: TT 11x4.5 props
« Reply #11 on: January 05, 2018, 08:13:36 PM »
  Too small and too much pitch for the 40VF and WAY too small and WAY too much pitch for the 46VF, or at least without other power-reducing changes. For example, the first-generation piped setup for the 40VF used a 12-3.25 Bolly, and that was still too much pitch/too fast for the 46VF with the same venturi. And the sound it made was, charitably, quite noticeable. It wasn't an ideal system, but it was dead-nuts reliable and repeatable - and VASTLY BETTER than anything that had come before it.
I ran the TT11-4.5 on the 35FP with a muffler, (a LOOOOONG time ago) it was really not enough prop to take full advantage of the power. It might be better on the 40FP, to keep it unloaded enough to suck fuel.
« Last Edit: January 06, 2018, 06:31:37 AM by Brett Buck »
Re: TT 11x4.5 props
« Reply #12 on: January 05, 2018, 09:10:55 PM »
They are  good for
Brodak 40
Magnum 36
Thunder Tiger 36
TS 39
FP and LA 35 - 46 (  yes  people are happy with this prop on LA 46)
Webra 36
ASP 32
Tower 40
HP 40
OS 35 AX ( i used these to test and develop this new engine)
Offline Steve_Pollock
Re: TT 11x4.5 props
« Reply #13 on: January 05, 2018, 09:35:32 PM »
Rick, please add my name for a bag (6 or 10) of these props.  Thank you.
Offline Joseph Patterson
  • AMA member- Supporter
Re: TT 11x4.5 props
« Reply #14 on: January 05, 2018, 09:53:39 PM »
     I'LL take (24) of the TT 11X4.5 props at your current quote. Any idea when you will get'em in? By the way, they work real good on our LA 46's down here in S. LA.
                   Doug
« Last Edit: January 08, 2018, 08:19:37 AM by Joseph Patterson »
Offline Allan Perret
  • Proverbs
Re: TT 11x4.5 props
« Reply #15 on: January 05, 2018, 09:58:03 PM »
6 of each size
Make it two 6-pack of the 11's,
     and one 6-pack of the 12's
« Last Edit: January 07, 2018, 11:30:27 AM by Allan Perret »
Allan Perret
AMA 302406
Slidell, Louisiana
Re: TT 11x4.5 props
« Reply #16 on: January 05, 2018, 10:19:57 PM »
    These props are a good match for what ever airplane/engine combination that they WORK on. If you fly airplanes with .32  to .46 size engines on them, you should have a half dozen or so of these in your prop box. You should also have as many of some other brands of props to try through the trimming process, also. A prop will work because of other factors in the equation of a particular airplane, including the engine, plug , model size and weight. And this prop might not work at it's best until to clip it 1/8" or so. I have a Sakitumi with a OS.LA.46 on it. It flew fine with an LA.40 on it but I wanted to get some time and experience with the LA.46, so put one of those on. The usual LA.46 props were a bit too much for the airplane, and it tended to wind up. I forget all the different combinations of prop and line length and such that i experimented with. I tried the TT 11-4.5 and it all started to come together. You might think that it wouldn't be quite enough prop for a .46, but it works with that engine on that airplane. You just can't tell until you try it. The long and short of it is, you should have these in your flight box, but it shouldn't be the only prop you have in there.
    I need to check my prop stock and will check in tomorrow if I need some. Have you got an estimation when you will get delivery and when we should be able to make payment?
   Thanks a lot,
Offline Steve Lotz
Re: TT 11x4.5 props
« Reply #17 on: January 06, 2018, 05:09:13 AM »
I'd take 6 of the 11"x 4.5" props.
Offline ray copeland
Re: TT 11x4.5 props
« Reply #18 on: January 06, 2018, 05:47:35 AM »
Re: TT 11x4.5 props
« Reply #19 on: January 06, 2018, 09:55:03 AM »
   I'll take 6 of the 11-4.5 props.
   I'll verify the part number for the 12.5-5.5 is #3518.
    And I'll take 6 of those if they get made.
   These have been working pretty nicely on a ST.60.
   I have heard of guys running them on ST.G.51's , but that is a lot of pitch,
   And need to try one for myself.
   Thanks a lot!
Re: TT 11x4.5 props
« Reply #20 on: January 06, 2018, 10:35:29 AM »
  Rick, I forgot to add that I'll take (6) of the TT 12.5 X 5.5 props too if you can get'em.
     Doug Patterson
« Last Edit: February 14, 2018, 08:39:38 AM by Joseph Patterson »
  • AMA 931589
Re: TT 11x4.5 props
« Reply #21 on: January 06, 2018, 11:33:36 AM »
Time on the props would be about 8 weeks after I order them.SEND NO MONEY till I send them. But first and most importantly I need a BUNCH more that want these. I will need to unload 500 of these. They did drop the minimum from over 1000 to make a run but I cant get stuck with 300 extra props. I will keep this up for a week to see how it goes. Just please don't say that you will take 100 just to get me to order them then only take 12. I am not a rich man.
Rick
Rick Bollinger
AMA 931589
Re: TT 11x4.5 props
« Reply #22 on: January 06, 2018, 11:41:11 AM »
Just curious what these props look like and why they have attracted this much attention (although not yet enough, I see. c'mon guys, help Rick make the grade!).  Wood?  Carbon?  3 or 2 blade? Undercambered? not?  etc.  Anyone got a picture and an explanation for their apparent desirability?
Online Dan Berry
Re: TT 11x4.5 props
« Reply #23 on: January 06, 2018, 11:44:12 AM »
I'm in for a dozen.
Offline Dane Martin
  • heli pilot BHOR
Re: TT 11x4.5 props
« Reply #24 on: January 06, 2018, 12:45:44 PM »
I'm only in because of peer pressure. It seems to be the cool thing to do.....
Re: TT 11x4.5 props
« Reply #25 on: January 06, 2018, 12:57:47 PM »
   Hi Ted;
   I don't have a picture but you could search eBay or just google Thunder Tiger Cyclone Prop images for a photo. They are two blade, molded plastic, and not too heavy. I would be interested in a comparison of the plastic used in these from China compared to the APC props made here. They are true pitch to their markings, at least the ones I have checked have been. Sort of narrowish blade and not too thick. They just work well and are usually the first prop a lot of guys try on a new model. For the price, even with the price increase, they are a good deal for a quality, consistent prop for the Joe Bellcranks of the world.
    Dan Mcentee
Offline James Holford
Re: TT 11x4.5 props
« Reply #26 on: January 06, 2018, 01:36:56 PM »
Ill take 3 of the 11x4.5
« Last Edit: January 06, 2018, 01:59:12 PM by James Holford »
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Offline Jim Svitko
Re: TT 11x4.5 props
« Reply #27 on: January 06, 2018, 01:51:12 PM »
A few years ago one of the guys at the field handed me one of these props and said "try this."  I put it on a plane that was powered by an LA 46.  The difference was like night and day.  Climb performance was fantastic, much better than the Zinger (no surprise there), BY & O, or any other prop I had at that time.
Regarding the prop's features, I have no idea why this prop works so well but it does.  Most of the 11 X 4.5 weigh about 1.2 to 1.3 ounces.  I am not sure of the material but it is quite stiff.
There is an under camber to the blades.  The stated pitch is 4.5 but I have measured some at 5.
Offline gene poremba
Re: TT 11x4.5 props
« Reply #28 on: January 06, 2018, 01:52:56 PM »
 Please put me down for 6 of the 11x4.5 props. Thank you .....Gene Poremba
Offline Jim Svitko
Re: TT 11x4.5 props
« Reply #29 on: January 06, 2018, 02:08:36 PM »
Forgot to mention:  I will take six (6) of the 11 X 4.5 and six (6) of the 12.5 X 5.5.
The first pack of six that I bought cost something like $12 plus tax.  For about $2 each, I should have bought many more at that price.
Regarding stiffness as compared to other props:  Of course, it is not as stiff as a carbon fiber prop.  I would say that it is about equal in stiffness, maybe a bit less, to a similarly sized wood prop, such as BY & O.
Online Brad LaPointe
Re: TT 11x4.5 props
« Reply #30 on: January 06, 2018, 02:10:04 PM »
Please put me down for 12 ,11x4.5 props .
Brad LaPointe
Offline George Truett
Re: TT 11x4.5 props
« Reply #31 on: January 06, 2018, 02:16:20 PM »
I'll take 10 or 12 of the 11x4.5 depending how they are packaged.
« Last Edit: January 06, 2018, 04:52:03 PM by George Truett »
Offline Guy B Jr
Re: TT 11x4.5 props
« Reply #32 on: January 06, 2018, 10:59:36 PM »
Rick,
I would like two 6-packs of the 11x4.5 props. (total - 12 props) Thanks for going to this trouble for your brothers.
Guy Blankinship
  • AMA 931589
Re: TT 11x4.5 props
« Reply #33 on: January 07, 2018, 10:51:51 AM »
Bump...  Still a ways to go.
Rick Bollinger
AMA 931589
Offline Larry Lindburg
Re: TT 11x4.5 props
« Reply #34 on: January 07, 2018, 08:06:03 PM »
The 11-4.5 worked well with my RoJett 40.
AMA 95707
Offline Larry Fruits
Re: TT 11x4.5 props
« Reply #35 on: January 07, 2018, 11:56:48 PM »
Rick,
 I would like six (6) of the 11 X 4.5 and six (6) of the 12.5 X 5.5.
  Larry Fruits
Offline Dave Heinzman
Re: TT 11x4.5 props
« Reply #36 on: January 08, 2018, 08:08:27 AM »
I'll take 6 of the 11x4.5 props for sure and 6 of the 12x5.5 if they become available. hope this helps.    Thanks
Dave Heinzman
Offline Thomas Smeltzer
Re: TT 11x4.5 props
« Reply #37 on: January 08, 2018, 09:38:57 AM »
 I would take 12 - 11x4.5 and 12 - 12.5x5.5
 Tom
Offline Jerry Higgins
Re: TT 11x4.5 props
« Reply #38 on: January 09, 2018, 09:07:09 AM »
I'll take 24 ea 11 X 4.5 props.
Jerry Higgins
Re: TT 11x4.5 props
« Reply #39 on: January 09, 2018, 04:02:40 PM »
Rick, you can bump my order from 1 bag to three (3) bags, whether its 6 or 10.
Offline Dick Tyndall
Re: TT 11x4.5 props
« Reply #40 on: January 10, 2018, 03:07:25 PM »
   Put me on your list for (6) of the 11X4.5 props, please. Thanks.
                              Dick Tyndall
Offline B Norton
  • B-NO
Re: TT 11x4.5 props
« Reply #41 on: January 10, 2018, 05:50:56 PM »
I'll take 6 of the 11x4.5 .
Offline peabody
Re: TT 11x4.5 props
« Reply #42 on: January 11, 2018, 08:59:55 AM »
For some idiotic reason I feel compelled to add my name onto the list for a sack of them....
Offline tom_weedman
Re: TT 11x4.5 props
« Reply #43 on: January 11, 2018, 09:33:52 AM »
I will take a bag of the 12.5x5.5 props
Thanks Tom Weedman
AMA 63672
Offline Jim Svitko
Re: TT 11x4.5 props
« Reply #44 on: January 11, 2018, 11:09:20 AM »
Do we have enough control line stunt fliers remaining in this country (or the world) to achieve the minimum number of props required to make another production run?
We are not a market niche that enjoys economy of scale.
Offline Fredvon4
  • Central Texas
Re: TT 11x4.5 props
« Reply #45 on: January 11, 2018, 01:05:04 PM »
I just did a quick spread sheet
31 different names
307 each  of the 11x4.5  and 72 each of the 12.5x5.5 are asked for
long way to go to make sure Rick is not holding the bag on a bunch of props
does not look like the 12.5 x 5.5 will make the min for production deal worth doing
Fred von Gortler IV
Offline M Shipman
  • M. Shipman
  • South Texas
Re: TT 11x4.5 props
« Reply #46 on: January 11, 2018, 03:27:29 PM »
Put me down for 2 six packs of the 11x4.5
Offline Akihiro Danjo
Re: TT 11x4.5 props
« Reply #47 on: January 12, 2018, 05:25:37 AM »
Does anyone buy original YOSHIOKA's Glass Nylon Props from Yoshioka of Japan?
I called up Yoshioka today and they were very kind enough to answer my Qs.
Yoshioka have stopped producing their GN Props because the market is shrinking. Their late productions were done in China. That will the reason why TT have the copied molds. Of course Yoshioka still have the right of the props and TT's are illegal.
Yoshioka still have enough numbers of stocks, both 11x4.5 and 12x5.5. They stock less than a thousand but enough for our C/L market (I do know how many they stock now).
If someone want to buy a few hundreds of GN Props, they can offer Qty special rates.
Aki
« Last Edit: January 12, 2018, 05:45:59 AM by Akihiro Danjo »
Offline Harold Brewer
Re: TT 11x4.5 props
« Reply #48 on: January 12, 2018, 10:02:47 AM »
Rick -
        Put me down for eight props.
Brew   H^^
  • AMA 931589
Re: TT 11x4.5 props
« Reply #49 on: January 12, 2018, 03:21:17 PM »
Akihiro Danjo I spent quite a bit of time trying to contacting them a while back with no luck.
Rick Bollinger
AMA 931589
