  • July 25, 2025, 07:17:20 PM
Author Topic: Top Flite Tutor, the old original 35 kit, not the later ARF; how good ?  (Read 27700 times)
Offline raglafart
First off I'm in Australia
The kit is part of my friends estate, Ian Lemits.
Trying to come up with a fair price for it as I'm selling it for his widow Sandra.
It's a nib kit, opened, but like all of us the plan has been looked at a few times.
The box is good just some wear marks from storage and a bit of age distortion.
I've put it here as the shipping cost's the US will more than likely kill any interest from buyers from the US and as I say I'm just asking for a guide on pricing as one or two club member here in Australia have showed an interest so it's more than likely going to sell here. Just trying to do the right thing by Sandra
Cheers John
John Goodwin
AUS 21261
Offline Ralph Wenzel (d)
Re: Top Flite Tutor, the old original 35 kit, not the later ARF; how good ?
« Reply #1 on: January 24, 2009, 04:07:02 PM »
It's a pretty good flyer, especially if kept light. Small wing, y' know. I had one that lasted for 20+ years (with a few repairs . . .) and it flew well with an OS .35S, and weighed around 40 oz. Would have been better at 35 oz.
A reasonable price is around U$60 - U$75, depending.
Ralph Wenzel
AMA 495785 League City, TX
Offline peabody
« Reply #2 on: January 24, 2009, 04:35:35 PM »
I strongly believe that they are USUALLY way weigh heavy! They suffer from a lack of wing area compared to span.
That said, I have seen several fly well, but it was usually the flier.....
Offline Phil Spillman
« Reply #3 on: January 24, 2009, 06:45:55 PM »
Hi Ragla, Several years ago a friend prangued his Tutor and was about to burn the remains when I asked if he didn't want it anymore might I have it? He said sure and I took it home and rebuilt it. Rarely have I had a plane that I got as much enjoyment as I have had from this. Several years later while at the Brodak FlyIn I came upon a NIB Tutor kit for sale by a man selling stuff there I asked his price and he said $65.00. I bought it straight away on the spot!
The person who said that the wing is abit small is right but it's not that small that with a Brodak .40, La.40, FP .35/.40(modified for stunt) and probably many other similar engines you really do get a lot of bang for the buck!
I smashed my above noted Tutor and gave it to an upcoming guy of 73! He rebuilt it and then decided to quit larger planes and revert to .15's to .25's. He sold it back to me with a new LA .40 attached for whatever cash he had in it to fix plus the engine! I am still flying that Tutor and it may be seen in the most recent issue of CLW! It's even heavier now but for that reason it makes a great windy weather flier! Strictly for fun though..this is no contest queen!
Tally Ho,
Phil Spillman
Phil Spillman
Offline raglafart
« Reply #4 on: January 24, 2009, 10:50:05 PM »
Thanks so much guys. Just the sort of detailed information I was after. I'll point the guys in our club that showed an interest in the kit to you thoughts here.
Much appreciated.
Cheer John
John Goodwin
AUS 21261
« Reply #5 on: January 26, 2009, 10:25:45 AM »
Hi John/ Ragla, I forgot to mention that in resurrecting what has become known as "Stick Buns" the Navyish Tutor, I added a tripler of 1/2" balsa to the inside if the fuselage nose. This piece runs back to approximate the highpoint of the wing. I mount an engine of similar size to what I plane to use and shape the nose down to the mounted spinner. Once removed I add fibre glass and resin to this to give the front end a much stiffer platform to run the engine against.
Sure do wish my thoughts all came at one time so that I wouldn't have to Post these addendum's to my hints!
Tally Ho!
Phil Spillman
Phil Spillman
Offline Les Byrd
« Reply #6 on: January 27, 2009, 02:26:45 PM »
This kit was one of my first large models.  I was into scale at the time and so I installed a 3-line bellcrank and a throttled O.S. .35  I added some rounded wing tips and glummed some additional balsa onto the fuselage and came up with a Macchi Veltrol profile, flew it off grass in my wife's pasture-(she has the horses, I have the airplanes).  With a buddy, we'd fly missions, touch-n-go, land, taxi, and idle while refueling, change pilots and go all night.  It was not a light-weight, but it was a gas to fly anyway.
« Reply #7 on: January 27, 2009, 06:45:35 PM »
   I found them to be very good fliers. Both of mine were *feather light* with excellent wood. One was 31 oz with a Fox, the other was 27 oz with a Fox and 32 with an ST46(!). The 46 experiment was pretty interesting, and that was about as good as you could do at the time. Now, I would consider it to be perfect for a 20FP.
     Mine were bone stock with Monokote surfaces and painted fuselage. Whoever designed the airplane was an expert - it was beefed up quite a bit (big spars, and .070 balsa sheeting) so you could use monokote without losing too much rigidity/performance. Even the extra sheeting at the wing tip -  I used it but always looked like unnecessary dead weight, until about year ago when I realized it was there to keep the TE and LE from "shearing" relative to each other and greatly enhanced the torsional strength.
   The only change I would make if I were to make another would be to slightly alter the LE sheeting to cover the spar in the first open rib bay. It doesn't help the performance but I ended up inadvertently sticking the monokote to the spar when covering the wing, which was ugly. Of course, the rudder should be *dead straight ahead*, usually caveats about alignment, etc.
    I did my first complete pattern with a Tutor and a Fox - the first time it made it through the outside corners without the engine quitting. This was long before the Fox Burp Fix was discovered. I went back to do a second hourglass, and sure enough, it burped and quit at the third corner and that was the end of the day.
Offline Steve Fitton
« Reply #8 on: January 28, 2009, 12:10:01 PM »
When you hang a big motor like an ST46 on a small plane like the original Tutor, do you think you are in essence "fooling" the wing into thinking its bigger, like blown flaps on some full size jets?  I had a Tutor with a Fox when I was starting out, and often heard people say that the Tutor was the perfect example of a good design with too small a wing.  Arguably, Fitzgerald's Worlds plane would fall under the small wing/big engine family, even if the 75 is considerably detuned.  Plus there was that guy in Oz who hung a Stalker(?) 60 in a Nobler.  There is plenty of anecdotal evidence of this method working, but I'm not sure where the physics or aerodynamics come in.  How does one define "too small" (a wing) when people keep making them fly better with progressively bigger engines?  And then how could one go backwards and redefine the Tutor for an FP-20 vs a ST-46?
« Reply #9 on: January 28, 2009, 07:51:46 PM »
Hi Bret, The designer of the Tutor, I beleive, was GMA himself! Phil Spillman
Phil Spillman
« Reply #10 on: January 28, 2009, 08:32:13 PM »
    I don't think it has much to do with the wing size or making it seem bigger. The ST was an experiment, in one way, and the most practical solution to my other problem - that is, I knew an ST46 would keep running through outside corners! That's a lot more than I can say about the Fox, in those pre-bypass-stuffer days.
    The experiment part was to see if what was, at the time, a grotesque increase in "power" would make it work better in the wind. The answer is - sort of. To get the full effect of the ST, you needed a pretty larger-diameter prop. That killed the cornering, even compared to the Fox, and the resulting break caused the wild power burst problem. It certainly worked better than it did with a Fox, but it was not significantly better than the larger airplanes with half the power/weight ratio. At the time (and this was a long time ago, 1982) I had little idea how to go about fixing these problems. Running less diameter helped both issues, but reduced some of the beneficial effects. It certainly ran a lot more consistently that way. But in any case, as long as it was running 6" of pitch it was still going to whip up, and it was no better in that regard than airplanes twice the weight with the exact same engine.
     Of course, what I thought was a "grotesque" increase in the power really wasn't. An ST is certainly stronger than a Fox, but both are feeble and ineffective compared to even a Magnum 36. And although I hadn't quite worked through the math at the time, there's no way to make use of the superior capability of the ST46 on that airplane. Certainly the level flight power of the same airplane, flying slightly slower, was less than with the Fox, add in 2" more diameter, and it's down on shaft HP, too, compared to the Fox. Lower speed = less hp applied to the airplane = less thrust, more diameter = more efficient = less shaft HP required to maintain any particular speed. The static thrust was drastically higher, the acceleration out of the corners was somewhat improved, but that, too was a bit of a double-edged sword, since if you tried to get much power out of it, it tended to leap out of the corners, and the breaks were too strong. The only thing it did much better than with a Fox (aside from *continuing to run*, which is always a plus) was penetrate into the wind in the vertical 8, hourglass, and overhead 8. Although I couldn't put my finger on it at the time, the cornering was actually worse because I was swinging a lot of prop on a tiny airplane, and particularly with relatively tiny tail. And there was a bunch of extra weight in the nose, and a bunch of solder wrapped around the tail wheel strut to balance it, greatly increasing the pitch MOI.
    The bottom line, and this was well-understood at the time, airplanes running 4-2 break motors needed to be in a very small range of sizes to optimal performance. Too big, too much power variation, too little, poor handling characteristics.
    The 20FP/9-4 would solve a lot of those problems, mostly, by being able to run a smaller prop *with less pitch*. The combination of the low pitch and gentle response in a rich 2-stroke completely solves the "power burst" problem, and the smaller diameter at high revs permits the use of more shaft HP in level flight. The control response with the small prop would certainly be superior and much more consistent, and not cause a lot of trim problems. It would fly faster, but the smooth engine response would make that a very minor issue. So I expect that it would fly MUCH better with a 20FP than it did with an ST46.
     High rev/low pitch motors, even more so those with tuned pipes, don't seem to care very much what they are attached to. That's why you can put a 40, or a 91, in an Impact or similar, and get relatively small change in performance. You have to drastically detune them anyway, so when you use different motors, all you are doing is selecting for the run characteristics, not how much "power" they have. I don't really concern myself about being able to get enough power any more, it's a moot issue. But *how* it runs is critical.
     I don't think a lot of people have fully clued in to this situation, but I think my analysis is correct.
« Last Edit: January 29, 2009, 08:36:47 AM by Brett Buck »
« Reply #11 on: January 28, 2009, 08:41:31 PM »
   Really?  I am surprised to hear that, although it was clearly intended and marketed as a scaled-down Nobler.
   As lionized as he has been as a personality, George didn't really get enough credit for some of the engineering he did. "Stunting Can Be Smooth" is as sound a bit of reasoning as has ever been done in this event. Later on, he was so locked into his one approach that I think things sort of passed him by. He's hardly the only person that has ever fallen prey to that in this event - we are all prone to it. There are some real hallmark examples active even now.
   There were some pretty good reasons that the Old Masters got to be Old Masters!
« Reply #12 on: January 28, 2009, 09:12:58 PM »
The plans say "designed by Mark Bauer" along with "eng'r'd by Sid Axelrod" and "plans by Carl Lindee".  No mention of GMA anywhere on the plans, or box.
I paid $49.95 for one of the last TF Tutor kits.  At the time I figured I was paying too much, it was a solid $15 more then a Twister or Banshee kit.  I bought it more because TF kits were drying up then really wanting to build one.  It's probably worth what I paid now, but I wouldn't give that much for another one.  The quality seems pretty good, but nothing all that great.
« Reply #13 on: January 28, 2009, 09:20:20 PM »
  I was pretty sure it wasn't going to be GMA, I would have remembered that.
    I thought the engineering was awfully good, and very well-thought-out. Sid Axelrod (founder of Top Flite) was a master modeler.
« Reply #14 on: January 29, 2009, 08:50:27 AM »
Well, I guess I stand corrected! Although I truly thought that GMA was the man! Sorry for this error!
Tally Ho!
Phil Spillman
Phil Spillman
« Reply #15 on: January 29, 2009, 09:20:50 AM »
If you really think about it, GMA probably had some influence even tho it may not have been in person.  Look at how many planes use the Nobler wing and moments.  DOC Holliday
« Reply #16 on: January 29, 2009, 03:28:14 PM »
Thanks Brett for the Tutor FP20/ST46 comments.  Its some useful information, especially in light of an experimental project we are fooling with in our club here thats pretty similiar to the overengined Tutor project.  In this case it will be a Dreadnought 40 powered with a DS 60, but the pipe comments remind me that we have the capability of refitting the model with a piped magnum 36 pretty easily and then seeing which powertrain works better.
Offline dirty dan
« Reply #17 on: January 29, 2009, 06:31:29 PM »
I think Brett is exactly on the money in suggesting the (original) Tutor be combined with a box-stock 20FP. In fact, I used this design as a bit of inspiration when fiddling with scaling the Impact into what I call the Wimpact.
Brett is right again in referring to the design features. After I first came across the technique of sheeting the outboard wing bays I have used the same technique on every single built-up model.
While the ARF Tutor seems successful--we seem to see a lot of them around here--I kinda wonder why the original has not also been produced. Okay, it wouldn't be quite as magical with a 25LA bolted in the nose. But it would at least be decent, inexpensive and readily obtainable. Not to mention being a lot better combination than when fitted with a Fox 35!
Dan
Dan Rutherford
« Reply #18 on: January 29, 2009, 08:14:12 PM »
   There's a lot of that sort of thing going on now. Uncle Jimby will be test-flying his ARF Vector 40/piped RO-Jett 61 airplane this weekend, in preparation for his "real" model that is approaching final assembly. Oddly, it only weighs 2 oz more than the his other ARF Vector 40 w/PA40UL. Of course, that's a bit different from a big 4-2 break motor with a lot of pitch.
p.s. a followup - the RO-Jett 61/Vector ARF experiment appears to be extremely promising. Remarkable speed stability makes the cornering dead-consistent even with the basic airplane (ARF, so very crooked) out of trim. That's certainly not what happened with the Tutor/ST46. As I mentioned earlier, these sorts of engines/props hardly care what you hang them on.
« Last Edit: February 01, 2009, 06:30:16 PM by Brett Buck »
Eric Viglione
« Reply #19 on: January 30, 2009, 10:28:49 AM »
I think that's the whole point of Steve's club experiment. Instead of putting the 4/2 motor in a situation where there's a lot of 2 going on with a lot of pitch (said large, heavy plane) and potential wind up, put a big 4/2 motor in a small plane and never let it get near a 2. Just 4/4 chugging along. I seem to see a lot of pipe ships running in 4/4 mode as well lately. Ought to be interesting to see what comes of it. x:
EricV
   There's a lot of that sort of thing going on now...Of course, that's a bit different from a big 4-2 break motor with a lot of pitch.
« Reply #20 on: January 30, 2009, 12:35:11 PM »
After repaiing the Tutor we had a few times, we put a R/C glass mount (for inverted mode) on the nose to simulate the Imitation.  Put a Fox 35 on it and it was a very good flying plane!  It actually got lighter as we repaired it since the repairs were always done with contest wood.   ;D
IIRC, Uncle Jimby did fairly extensive modifications to one and it was published I believe.
AND, Flying Models published the Professor which was a built up fuselage take off on the Tutor by Mike Speedalire (sp?).
Mongo
« Reply #21 on: January 30, 2009, 05:50:28 PM »
   I think that was the Southern Gentleman, Mr.  Dave Hemstrought. Uncle Jimby has done a lot of crazy stuff (like MODIFYING the otherwise perfect Infinity design to his crazy Berkeley leftist specifications), appeared on Merv Griffin and the Gong Show, and put out a children's album - but not a modified Tutor.
« Reply #22 on: January 30, 2009, 09:01:11 PM »
Bret is correct here! Dave Hemstrough did publish an article on his modifications to the original Tutor. I do not remember the gist of the remarks but I did see him in Huntersville in 2000 at their fall contest and he said that those changes improved greatly over the box stock variety! It was published in one of the big three magazines as I recall. Might have been in the early to mid 80's.
Tally Ho!
Phil Spillman
Phil Spillman
Offline Bob Kruger
« Reply #23 on: January 31, 2009, 07:52:50 AM »
Tally Ho!
Phil Spillman
Attached is a scan from Model Airplane News of the mods made by Dave H.  To summarize, he shortened the tail moment by about 1.5", eliminated the turtle deck, added 2" wing tips, did some cutouts to lighten the fuselage, changed leadout location, and reshaped the elevator.
V/r
Bob
« Last Edit: January 31, 2009, 08:37:07 AM by Bob Kruger »
Bob Kruger
AMA 42014
« Reply #24 on: January 31, 2009, 03:03:00 PM »
Thanks for the drawing.  I have just printed off a copy just for reference.  When the Tutor first came out I was at the NATS and there was a fellow there with a table full of engines.  Bought a Fox 35 Stunt for $12.00 and the Tutor kit.  When I told them it was for my son they wanted to know where he was.  I thought I was going to get tarred and feathered when I told them he was still at home.  He has missed very few NATS until he grew up.  DOC Holliday
« Reply #25 on: February 01, 2009, 06:26:12 PM »
    It will indeed. I predict, with the massive pitch, that it will whip up furiously, but there's one easy way to find out.
   The most important breakthrough in stunt in the last 40 years was not quite the tuned pipe engine. It was getting rid of 6"+ pitch props.
« Reply #26 on: February 02, 2009, 07:39:10 AM »
It just might wind up furiously, but then again running a full 6 pitch, etc wasn't exactly where we intend to start out at either.  Nonetheless, as this is an experimental job and not somebodys Nats plane effort, it should prove interesting to play with without having alot of mental angst that this is some new setup that just has to work.  As I alluded to earlier, it may end up being used for magnum 36/pipe development more than DS-60/prop development as time goes by.  There is alot of stuff we can do with the plane...
Offline bill marvel
  • Lafayette Esquadrille, St. Louis
« Reply #27 on: February 02, 2009, 10:10:10 AM »
Are the plans for the Top Flite Tudor available somewhere?
regards,
bill marvel
Bill Marvel, AMA 793835
Welcome to Stunt Hangar
Offline Bob Kruger
« Reply #28 on: February 02, 2009, 12:44:56 PM »
regards,
bill marvel
Bill;
Tom Dixon lists it on his site under the "Classic" (Pre-1970) category.  I don't think the Tutor is a classic design, as I remember it coming out in the late 1970s.  At the same time, I could be wrong, and it would not be the first time today...
http://members.tripod.com/~TomDixon/plans2.htm
V/r
Bob
Bob Kruger
AMA 42014
Offline Ed Keller
« Reply #29 on: February 02, 2009, 01:01:58 PM »
I am surprised no one has mentioned Jim Armour's modified Tutor project that was published, I believe, in MA back in the late 80's or early 90's. Perhaps his mods were so great that you could not still consider the resulting plane a Tutor. At any rate, it was one good looking plane. Wonder if anyone knows if this airplane still exists?  Ed
« Reply #30 on: February 02, 2009, 03:54:48 PM »
I agree, the Top FLite Tutor is not Classic legal.  It was at a Lake Charles LA NATS that I bought one of the new kits.  It had just been introduced.  That was in the 70's.  DOC Holliday
