  • June 22, 2025, 05:00:20 AM
Author Topic: Top Flite Nobler, Kit bellcrank  (Read 2401 times)
Offline Ronald Eshleman
« on: February 17, 2013, 04:05:56 PM »
I have a Top Flite Nobler, kit built, hand-me-down Nobler.  In the fall, it had a hard crash.  One leadout tore off at the bellcrank.  Where does one cut to get into the bellcrank to put on new new leadout wires?
Offline Bob Hudak
Re: Top Flite Nobler, Kit bellcrank
« Reply #1 on: February 17, 2013, 05:56:29 PM »
I don't have the plans anymore but if my memory serves me well it's right under the cockpit area in the wing.
 Bob
350838
Offline Gerald Arana
« Reply #2 on: February 17, 2013, 06:06:01 PM »
The bellcrank pivot point is 3-1/2" behind the leading edge of the wing which is at the rear of the spar. Whatever you do don't cut into the spar..........  n1
Good luck. I had one that the same thing happened to and I gave it to a fellow modeler after I cut the top and bottom of the fuse off.  Shouldn't be to hard of a fix.
Jerry
« Reply #3 on: October 04, 2016, 09:37:53 AM »
How do I register my Ringmaster flights for the world wide flyin? The web site is not co operating?
Online John Park
  • Agricola
« Reply #4 on: October 04, 2016, 10:06:13 AM »
If it's an ordinary Green Box Nobler, this should show you where to cut: http://www.outerzone.co.uk/plan_details.asp?ID=525
« Reply #5 on: October 04, 2016, 05:01:55 PM »
I once had to locate a "hidden" bellcrank, mainly because the pivot needed some oil.  Lucky for me, the "pivot" was a steel machine screw.  I found it using a magnet! Then, a couple very small holes in the sheet balsa allowed me to squirt in some oil.  It worked.
« Reply #6 on: October 04, 2016, 05:17:55 PM »
The original thread is three years old!  He just piggy-backed a question about the Ringmaster Roundup onto it!
« Reply #7 on: October 04, 2016, 06:02:04 PM »
I hate it when that happens...  Guess I'm too old to stand the stress!!!  LL~ LL~ LL~
And He's obviously too lazy to start a new thread!
« Reply #8 on: October 05, 2016, 09:41:09 AM »
He's posted several times of his problem on several threads. S?P
