  • June 19, 2025, 08:42:25 AM
Author Topic: fuel mixin  (Read 1010 times)
Offline Bootlegger
fuel mixin
« on: September 04, 2021, 02:53:31 PM »
 :!   Guys somewhere I read that when you mix your own you should let it set for aa period of time before using it..  What are yall's thoughts.  and thanks.. n~ #^
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Reptoid
Re: fuel mixin
« Reply #1 on: September 04, 2021, 03:05:24 PM »
I did see that in print years ago but I'm pretty sure that was an old wives tale. I've been mixing my own for over 50 years and could never tell any difference if they were the same mixture
       Don
       AMA # 3882
Offline Jim Hoffman
Re: fuel mixin
« Reply #2 on: September 04, 2021, 04:01:58 PM »
I mix my own.   There is no need or reason to let it age.
I also mix hi and low nitro fuels in the airplane fuel tank to adjust nitro content as the outside air temperatures increase
Offline Bootlegger
Re: fuel mixin
« Reply #3 on: September 04, 2021, 08:14:29 PM »
 n1 n1 n1 y1 y1  Thanx Men, I knew that the correct answer was here !!!  much obliged   n~ :!
Gil Causey
AMA# 6964
