  • July 15, 2025, 07:59:40 AM
Author Topic: To Paul Taylor  (Read 2429 times)
Offline Bill Gruby
To Paul Taylor
« on: June 06, 2010, 08:10:27 AM »
 Hi Paul;
  When you are done playin around with that Delrin and Aluminum you have now and wish to move up a notch to bigger stull I will send you a piece of this. 5.25 diameter X 24.00 long 7075 T3 Aluminun. It may take you a few days to turn the OD to size but you will get plenty of Lathe hands on experience.   LL~ LL~ LL~ LL~ LL~
 "G-Man"  VD~ S?P VD~
Bill Gruby
AMA 94433
MECA 5393-10
Offline John Cralley
Re: To Paul Taylor
« Reply #1 on: June 06, 2010, 08:30:07 AM »
Hey Gruby,
T3 aluminun  ::) --- is this a new kind of alloy??? Maybe your spell check is broken!!! LOL  ;D
John Cralley
AMA 52183
Central Illinois
Offline Garf
    • Hangar Flying
Re: To Paul Taylor
« Reply #2 on: June 06, 2010, 09:10:49 AM »
T-3 is the state of hardness of the metal. -0 is soft, T-4 is solution heat treated, T-3 is solution heat treated and cold worked. 7075 is usually T-6.
Offline Phil Coopy
Re: To Paul Taylor
« Reply #3 on: June 06, 2010, 09:21:53 AM »
Bill,
You can laff, but I used some of that stuff to turn fancy waterpump pulleys for my flathead Ford.
Phil
Offline Bill Gruby
Re: To Paul Taylor
« Reply #4 on: June 06, 2010, 10:12:07 AM »
Bill,
Phil
 John ; sorry about the Typo nice catch
 Garf; you are correct it is usually T6, this was special order for easier machining.
 Phil; no way will I laff, I've seen this used for lots of different things. This particular piece is for front and rear crankcases on an 18 cyl. radial engine I am going to build starting in November.   VD~
  "Billy G"   %^@
Bill Gruby
AMA 94433
MECA 5393-10
Offline Clayton Berry
  • Grey haired kid to be wary of
Re: To Paul Taylor
« Reply #5 on: June 06, 2010, 11:08:05 AM »
  "Billy G"   %^@
Eighteen cylinders...  On a Twister.  I'm excited already.  Hmmm.  Dope over dyed silkspan.  Very cool.
Clayton - forever busy committing random acts of coolness
Offline Bill Gruby
Re: To Paul Taylor
« Reply #6 on: June 06, 2010, 11:53:13 AM »
  Clayton;
  That might be a cool project except the completed engine weighs in at 18.75 lbs. Wing loading would be a problem for sure, then there is the arm loading.  LL~ LL~ LL~ LL~ LL~
 "Billy G"   VD~
Bill Gruby
AMA 94433
MECA 5393-10
Online Joe Gilbert
Re: To Paul Taylor
« Reply #7 on: June 06, 2010, 12:22:41 PM »
Bill, how big around will it be.
Joe Gilbert
Offline Bill Gruby
Re: To Paul Taylor
« Reply #8 on: June 06, 2010, 01:34:39 PM »
 Joe;
  Diameter 11.25 inches Length 11.75 inches. Prop Diameter 26.00 inches.
  "Billy G"   VD~
Bill Gruby
AMA 94433
MECA 5393-10
Online Joe Gilbert
Re: To Paul Taylor
« Reply #9 on: June 06, 2010, 02:36:45 PM »
way cool
Joe Gilbert
Offline dennis lipsett
Re: To Paul Taylor
« Reply #10 on: June 06, 2010, 06:41:10 PM »
Joe;
  "Billy G"   VD~
Bill,
The amazing thing is that you can legally build and fly that engine on a model over 55 lbs with waiver and even compete with it . Some of the IMAC models are up to 30 inch props. That is ulltra light sized for sure
Basically the 18 cylinder would be cool on a model of the corsair that They did install one on for evaluation.
If you build it I'll pit for you. H++l I'll even hand prop it for you.
dennis
« Last Edit: June 08, 2010, 10:26:45 PM by Bill Little »
Re: To Paul Taylor
« Reply #11 on: June 06, 2010, 08:27:57 PM »
G-Man,
I have not had a chance to get over to my dad's house. It will take me a few hours to figure out just what I need to do. I need to figure out how big to drill the holes for the venturi's and it will take the better part of a day to get everything gathered and setup.
Ryan came home this weekend, and next weekend we have plans, then the next weekend I will be driving back from some place in PA.
Seems like that would make a venturi for you BA RM? LL~ LL~
Offline Richard Grogan
Re: To Paul Taylor
« Reply #12 on: June 07, 2010, 12:46:43 AM »
I predict a bigger,maybe more stealth,Sooper Dooperer Ringmaster on the horizon! But better get the SDR finished first big bro!  LL~
Long Live the CL Crowd!
                  AMA 85745
Offline Bill Gruby
Re: To Paul Taylor
« Reply #13 on: June 07, 2010, 06:34:45 AM »
 I have to get all the irons out of the fire before I can start this project. I can't jump from one to another. As you know it will take about 2500 hrs. to complete. 1 yr. at 40 hrs./wk - 2080 hrs. I'm 64 and no way can I stand in front of a lathe or milling machine for 8 hrs. a day anymore.  LL~ It will get done however long it takes. This is my last big project.
 "Billy G" H^^
Bill Gruby
AMA 94433
MECA 5393-10
Offline Clancy Arnold
Re: To Paul Taylor
« Reply #14 on: June 07, 2010, 07:32:06 AM »
G-Man
A proposed schedule:
Finish all the parts by Roundup 2012.
Bring the parts to the Roundup 2012 and we can then ALL help you assemble it!
Clancy
I said that with a straight face?
Clancy Arnold
U/Tronics Control
Offline Bill Gruby
Re: To Paul Taylor
« Reply #15 on: June 07, 2010, 07:39:17 AM »
G-Man
Clancy
 Clancy you don't know what a straight face is.  LL~  Estimated assembly time once all parts are made 51 hrs.
 "Billy G"   VD~
Bill Gruby
AMA 94433
MECA 5393-10
Offline Garf
    • Hangar Flying
Re: To Paul Taylor
« Reply #16 on: June 07, 2010, 08:46:23 AM »
That's going to have to be one big ringmaster for this thing. I want to be there for the first flight of the Ringmonster.
Offline Bill Gruby
Re: To Paul Taylor
« Reply #17 on: June 08, 2010, 04:30:32 AM »
 A 96" span Ringmaster Biplane comes to mind Phil.  S?P S?P
 "Billy G"  ~>
Bill Gruby
AMA 94433
MECA 5393-10
Offline Leo Mehl
Re: To Paul Taylor
« Reply #18 on: June 14, 2010, 10:18:30 AM »
 "Billy G" H^^
Comon Billy 64 is not old 78 is old! LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ HB~>
