  • June 15, 2025, 10:27:01 PM
Author Topic: Tudor II  (Read 6419 times)
Offline sadams714441
Tudor II
« on: February 22, 2006, 01:13:28 PM »
What has everyone been doing when it comes to mounting the tank ? Are you using the tie wraps or are you using an adjustable mount mounted to the back of the tank
Steve Adams
Offline Leester
Re: Tudor II
« Reply #1 on: February 22, 2006, 01:45:58 PM »
You will want to make it adjustable. If you are using a plastic tank you can put J bolts 2 on top and 2 on the bottum leaving room to move it up and down and put ply shims top or bottum and secure with rubber bands. Doesn't look real classy but gets the job done.
Leester
ama 830538
Online wwwarbird
Re: Tudor II
« Reply #2 on: February 22, 2006, 04:18:36 PM »
That's TUTOR II not TUDOR. :)
Re: Tudor II
« Reply #3 on: February 22, 2006, 05:14:21 PM »
Thanks Tudor
Steve Adams
Re: Tudor II
« Reply #4 on: February 22, 2006, 07:40:58 PM »
Yeah. "Tooter Too"!  ::)  Steve
Re: Tudor II
« Reply #5 on: February 28, 2006, 11:55:48 AM »
What tank did you use
Steve Adams
