General control line discussion => Open Forum => Topic started by: sadams714441 on February 22, 2006, 01:13:28 PM
What has everyone been doing when it comes to mounting the tank ? Are you using the tie wraps or are you using an adjustable mount mounted to the back of the tank
You will want to make it adjustable. If you are using a plastic tank you can put J bolts 2 on top and 2 on the bottum leaving room to move it up and down and put ply shims top or bottum and secure with rubber bands. Doesn't look real classy but gets the job done.
That's TUTOR II not TUDOR. :)
Thanks Tudor
Yeah. "Tooter Too"! ::) Steve
What tank did you use
