  • July 19, 2025, 01:57:20 AM
Author Topic: Three blade prop question  (Read 1652 times)
Offline Andrew Borgogna
  • Andy
« on: December 03, 2009, 09:12:24 PM »
I know this subject has been talked out before, but does anybody have a conversion table for replacing a two blade prop with a three blade prop.   This all relates to getting the right prop for my LA .65 on my Score.  Currently I am using a 12x5 Zinger and getting 4.5 second lap times on 60' lines.  I was considering moving to a 14x4 but that's a bit big in diameter so I would like to use an equivalent three blade if I could.
Andy
Andrew B. Borgogna
Offline Rudy Taube
  • Ret Flyboy
Re: Three blade prop question
« Reply #1 on: December 04, 2009, 12:48:35 AM »
Hi Andy,
Here is the quote from the package my Master Airscrew 3 blade came in:
2-Blade to 3-Blade Conversion: decrease diameter by 1" and increase pitch by 1" if possible. Adjust to 2" for larger diameters (14" and up).
Some E flyers are replacing their APC 12 x 6 E prop with a Master Airscrew 11 x 7   3 Blade prop. It seems to work very well and gives a little extra ground clearance. I just received mine, and will be giving it a try soon.
I hope this helps.
Regards,  H^^
Rudy
AMA 1667
Offline jfv
« Reply #2 on: December 04, 2009, 07:57:10 AM »
I found a study done on model airplane propellers that gave the following rules:
For three blades:  Diameter  ≈  0.904 times the diameter of an equivalent two blade prop.
For four blades:  Diameter  ≈  0.84 times the diameter of an equivalent two blade prop.
Can't find the original reference right now.  I will post the link when I get it.
Jim Vigani
« Reply #3 on: December 04, 2009, 08:45:19 AM »
It's probably just me, but I'd try a 12.5 x 4.5. APC, Zinger (make your won prop kit), or similar as a 2 blade or a 12 x 4.5 three blade.
  • Andy
« Reply #4 on: December 04, 2009, 10:11:30 AM »
Thanks a bunch guys, I will use and save your valuable information.
Andy
Andrew B. Borgogna
« Reply #5 on: December 04, 2009, 11:28:32 PM »
You mayu also take a look at XOAR props they make a 13X4, and a 13X5 that may fill the bill for you.
Offline Mike Scholtes
« Reply #6 on: December 05, 2009, 10:17:04 AM »
Hi Andrew:
You didn't ask this, but I think you are flying the Score on way too short lines. I have a Score with an Enya 61CXS Pro that I fly on 65' lines, with about 5.2 sec laps. A model that big and heavy needs more room to roam, I think. You will give yourself more airspace to develop the maneuvers on longer lines as all the maneuvers will be larger.
I use a Mejzlik carbon 3-blade 12.5 x 5.2 on the Enya, a non-piped engine. This prop is specifically for non-piped 60s. Beautifully made, reasonably priced. I believe Randy Smith sells them, along with the Enya motors. I can also give a great recommendation for the Enya 61. This is a new design, not the Enya clone of the old ST60.
