  • June 25, 2025, 05:42:38 AM
Author Topic: ...panty hose...  (Read 1898 times)
Offline Bootlegger
...panty hose...
« on: November 30, 2009, 09:22:15 AM »
  Now that I have yer attention, where do ya get your "O" rings that you use to hold your "Defuser's" on the venturi??
 I tried some a/c o rings and they didn't last but a few flights.
 I saw some made of "Buna" that I have seen in fuel syrenges, but need to access to some small amounts.
  Any suggestions will be appreciated..        D>K
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline stephen hollier
Re: ...panty hose...
« Reply #1 on: November 30, 2009, 11:08:42 AM »
Gil,
Try a hydraulice hose company. I even sold these when I worked for a friend as a fastener company.
Offline Jim Treace
  • 1979 600 Aerostar N79JT
« Reply #2 on: November 30, 2009, 11:43:06 AM »
I get mine at Lowes and Home Depot. They are the "Danco" brand. #8 and # 9 size fits OS LA 46, #10 fits ST 51.
Jim
Jim Treace
Ponte Vedra Beach, FL &
Paris, TN
AMA 855251 "Too soon we grow old...Too late we grow wise"
Offline Richard Grogan
« Reply #3 on: November 30, 2009, 11:47:49 AM »
try the Home Depot. I've got black silicone ones from them in the hardware or plumbing section. You can also use a piece of wire- wrapped a couple of times and twisted tight, and also small cable ties work. I think the wire works best...
Long Live the CL Crowd!
                  AMA 85745
« Reply #4 on: November 30, 2009, 04:27:53 PM »
you can also use the little silicon rubber bands that are used for tying braids in hair - you can buy pack of 50 or 100 for a dollar
being silicon - they re not affected by fuel etc like rubber is
Offline Gene Martine
  • Started flying 1952 (AMA 2903)
« Reply #5 on: November 30, 2009, 07:17:27 PM »
We use small Ty-Rap (wire ty's). They use them in electronics. Home depot or Lowes.
Gene
 S?P S?P S?P
Offline Bootlegger
« Reply #6 on: December 01, 2009, 03:58:59 PM »
      D>K   Thanks fellows, I sure do appreciate all the reply's..
Gil Causey
AMA# 6964
« Reply #7 on: December 01, 2009, 06:11:09 PM »
They forgot the auto parts stores that O-rings that are impervious(did I spell that) to most petrolium products.
Offline PerttiMe
« Reply #8 on: December 05, 2009, 07:04:01 AM »
Panty hose?
I hear R/C scale combat guys sometimes use pantyhose to give their planes a tougher surface. Not that it helps much in reducing the number of planes they go through... but at least the material is inexpensive.
Offline Gordon Tarbell
« Reply #9 on: December 05, 2009, 08:38:47 AM »
Did someone say combat fliers wear pantyhose to  look tougher ? Hmmm!
Gordon Tarbell AMA 15019
Offline PerttiMe
« Reply #10 on: December 05, 2009, 11:07:26 AM »
I don't think so... but maybe I should post the idea somewhere where they get to read about it.
