  • July 27, 2025, 04:42:19 AM
Author Topic: Thongs and lines.  (Read 3202 times)
Offline W.D. Roland
Thongs and lines.
« on: August 20, 2009, 06:55:42 PM »
Guys
I don't have a rule book and can not find the info on line so asking here.
(well I do have the 1974-75 rule book)
What are the requirements for thong?
Material and size?
Heavy shoe lace???
Part of pull test?
If so how to equal pull on lines during test.
Good source of lines or wire to make?
Stranded .015s
Currently flying on .018x 60.
Going to .015 should help---and go to 70ft?
Once I solve these 2 glitches its on to learning the pattern.
Practice site was dust bowl now mud hole.
Looks like this weekend it will be dry and ready for me to scare the ground with low pull outs from wing overs!!!
Will try not to make any tooth pics!
David
51336
David Roland
51336
Alan Hahn
Re: Thongs and lines.
« Reply #1 on: August 20, 2009, 07:04:46 PM »
Here's the official rule repository. This is everything you need. y1
http://modelaircraft.org/events/compreg.aspx
Note that they now include the date on the pdf file.
Offline jim gilmore
« Reply #2 on: August 20, 2009, 07:44:34 PM »
Some how this title gives me the wrong impression....
 VD~ VD~ VD~ HB~> HB~> HB~> HB~>
was thinking something about whaletails....
Offline Clancy Arnold
« Reply #3 on: August 20, 2009, 07:54:10 PM »
David
A good source of flying lines is Brodak Mfg.
As for the safety thong I buy 1/8 inch dia. nylon rope.  It will pass any pull test that is required.
Clancy
Clancy Arnold
U/Tronics Control
« Reply #4 on: August 20, 2009, 08:21:44 PM »
Guys
Material and size?
Heavy shoe lace???
Part of pull test?
Stranded .015s
   The safety thong can be made of anything that passes the pull test. I would recommend braided nylon bootstrings - they seem to be more durable than just about anything else. The thong is pull-test separately from the lines, but to the same level of stress as the lines. You hook the thong up to the pull test machine and pull on the handle, not the airplane.
    As far as lines go, i get mine from MBS Model supply on 1000 ft reels. The minimum diameter is set by the weight of the airplane, per the table in the rule book. Most of the time you probably want the smallest diameter, but not necessarily - I would be afraid to fly a 63 oz 61-sized piped plane on .015 in any sort of wind even thought it's legal, and sometimes the performance is better with larger-than-minimum lines because they stretch less. The length can be anything from 26 feet to 70 (center of airplane to handle, not actually the line length). What you want it to be depends on the airplane, the power, and a lot of factors. I experiment with line lengths in 1 foot increments with new airplanes, and 1 foot can make a huge difference in the performance. You don't menytion the airplane and engines, but a typical 35-sized stunt trainer with a 25LA, 25FP, 20FP, Veco 19,  etc, I would start with .015x60-62 (eyelet to eyelet) and experiment. Same airplane with a Fox 35, McCoy, etc, maybe .015x56-58. For a 40-60-sized piped airplane I would suggest .018x64.
Offline W.D. Roland
« Reply #5 on: August 20, 2009, 08:23:47 PM »
For some reason this computer will not do PDF!
I loves to tell Microsoft about the problem but Microsoft never sends a solution--for 7 years now!!
Can someone copy past to word or something and post or pm it?
That would be great.
Jim
That was my thoughts while typing it.
Now the wife wants a safety thong! LL~
Wonder how she will look with the nylon rope--1/8in at that!
So Brodack and nylon rope is the cure.
What about the pull test?
just slide rope to center of handle??
Thanks guys!
David Roland
51336
« Reply #6 on: August 20, 2009, 08:27:24 PM »
A heavy shoelace works fine.  I use a lanyard from an ID badge.  The thong gets pull tested separately.  One holds the handle, and the pull test guy or machine pulls on the other end of the thong.
Everybody I know gets their lines from http://www.mbsmodelsupply.com/  .  Melvin brings his stuff to the Nats.  I stock up once a year.
Offline Richard Grogan
« Reply #7 on: August 20, 2009, 08:30:58 PM »
For thong material, I buy this very soft nylon rope material (sabout 1/8") from Home Depot. Its in their department with the bungee cords and tie down/ come-along type materials. You get a bag full of about 50',or more, for about 3.00,and enough to last a lifetime...
Long Live the CL Crowd!
                  AMA 85745
Offline W.D. Roland
« Reply #8 on: August 20, 2009, 08:42:15 PM »
Ah
Thanks Brett
That makes sense on thong pull test--I see it now.
Airplanes are all .35
Air or King Cobra Midwest with a McCoy almost 40 years old and looks every bit of it.
The 2 shoestrings one OS .35 the other a fox at 31 and 26 oz
20 year old smoothie fox at 42oz
Recent Chipmunk at 44oz ST.35stunt modified.
And(i need a drum roll here) a Midwest p-40 profile at 69oz! LL~
It stays on the wall.
The cobra should be a winner in profile as it will scare all others out of the sky! LL~
So it looks like I have plenty of tooth pick making equipment ready.
Hope it does not come to that!!
David
51336
David Roland
51336
Alan Hahn
« Reply #9 on: August 20, 2009, 08:47:46 PM »
....................<snip>
Get your pdf reader from
http://get.adobe.com/reader/
it's free.
Offline W.D. Roland
« Reply #10 on: August 20, 2009, 08:48:45 PM »
Thanks Howard
Will check Melvin out.
Did you look at our younger self's?
http://stunthanger.com/smf/index.php?topic=13543.0
Click on pics and click again and they clear up.
I can find you can you find me?
Home depot it is Richard!
Thanks guys!
David
51336
David Roland
51336
Offline W.D. Roland
« Reply #11 on: August 20, 2009, 08:53:06 PM »
it's free.
Alan
Have done that repeatedly.
even after reformatting.
Guys if I don't go finish changing the oil in wife's Miata shes gonna refuse to try out the nylon rope!  n~
will check back shortly
David
David Roland
51336
« Reply #12 on: August 20, 2009, 09:02:01 PM »
She's gonna love that"soft" nylon rope! LL~ I knew it!  LL~
                  AMA 85745
« Reply #13 on: August 20, 2009, 09:18:35 PM »
   Hopefully it's a strong wall.
Alan Hahn
« Reply #14 on: August 20, 2009, 09:58:35 PM »
Alan
David
Well I use a Mac and have no issues. Also have Acrobat on several PC's at work, also with no issues. Those are running W2000 (1) and XP (2). I have no clue how you can put up with not being able to read pdf--most documentation on the web is in pdf.
AFAIK, there isn't much that will convert pdf to MS Word.
Anyway welcome back to CL! :)
Offline W.D. Roland
« Reply #15 on: August 20, 2009, 10:02:25 PM »
The silly thing flies fairly good
Get very walery if  you try a square corner and even then its large and round.
Its a very nice airplane with an experiment gone wrong paint job.
One day sanding and monokote should help it out.
Richard
She says it tickles and is not going to do a very good job of keeping the castor oil off her while launching airplanes!
My opinion of the situation is #^ n~ #^ n~ #^
Good night guys and thanks for all the help!
David
51336
David Roland
51336
Offline W.D. Roland
« Reply #16 on: August 20, 2009, 10:06:48 PM »
Thanks Alan
probably would help if I stay out of the registry.
I usually email wife link at work and she prints and bring it home.
Need to find out what PDF need on in the registry to work.
A learning curve.......
Bed is calling my name
David
David Roland
51336
