Rusty, about the shrink tubing...some like to color code their lines to their leadouts...red or black, etc. I just make them all the same color, so that I won't fall into the
trap of relying on color codes to hook up the lines correctly.
Whatever procedure you decide on, think about it, and repeat it faithfully. I take my handle off first, roll up the lines, leaving both clips on the handle and a clip on the rear leadout. All goes into a quart Ziplock Freezer bag. The handle is roughly color coded to the plane, and the line spools are marked for the plane. When I hook up the lines, I hook the lines onto the leadouts first...one clip on the plane and one on one line...can't mess that up too easy. When I get the lines out, I pull on the lines to find the "up" line, and hook it to the "up" side of the handle. If I get that right, the rest is automatic. Then, I hold up on the handle, look at the elevator, and then look at the handle...back to the elevator and then the handle. This has prevented me from
never ever hooking the lines up backwards, starting from Jr. Highskool. So far, so good!
