I have a Sonic Tronic charger that the metal shaft is coming loose from the handle. I believe this is causing a short, I noticed this when I went to charge it the light on the wall unit flickers off and on when I wiggling the metal shaft. I would like to know if it is possible to cut off the rubber coating on the handle to repair this, and what do you use to replace the orange rubber on the handle with?
