  • July 18, 2025, 09:14:14 AM
Author Topic: The next big thing in Stunt? - The 4 stroke or Electric or tuned pipe killer.  (Read 4833 times)
I have been toying around with what to do engine wise for a while now.
Everyone is quite impressed with how strong the most recent dominant stunt engines such as Electric have become. -
Tuned pipes were very big in the mid 90's along with 4strokes.
Many people are searching for the next big thing in stunt power - always looking for more grunt and constant speed.
I have been doing alot of testing with a great little engine -
A Micro Jet turbine engine. The RC boys have been using it in Jets for along time and at full throttle they provide STRONG CONSTANT THRUST.
I picked this New model up which is avaliable online and I have been blown away with its power and constant speed.
Lap times can be slowed to 6 second Laps, you can adjust the Fan Blade to have low pitch and run high thrust - and acheive the power of the strongest Piped ship, the thrust of a 4 Stroke on Steroids But easy reliable power.
We have modified an exisiting stunter to house the turbine and the flights so far have been nothing short of breathtaking.
I know your thinking about the weight : So here are some specs :
Weight : 13.9 Oz Complete with all Parts
Thrust is at 1.7kg- albeit during flight with a low pitch fan turbine it works.
Here are a few more pics.
Wind ? No problem.. Constant Speed VERY. - Next big thing ? I think so.
Offline Andrew Tinsley
That sounds fascinating! I think lots of people will jump on the bandwagon.....................................hold on a minute, isn't it April 1st?
Andrew.
BMFA Number 64862
Ive had good success with the power delivery - I dont think its' any bandwagon - Many said electric was a fad..
This is another engine choice at our disposal - Less Drag - No P Factor, constant power. I like what I see.
Offline Rafael Gonzalez
How much if it likes grass, pavement or dirt for food you give up ? LL~ LL~ LL~
ChrisSarnowski
PJ,
If you look carefully at the pictures, you'll see that you have a few screws loose.
-Chris
Safety is Paramount
Offline Mike Anderson
For US flyers, here is a pertinent document  -
http://www.modelaircraft.org/files/510-a
(also, attached below)
That is just the Safety regulations - there are 12 OTHER documents related to model Turbine operation, many of which mention C/L models in the title.
http://www.modelaircraft.org/documents.aspx#Turbines
Mike@   AMA 10086
Central Iowa
Offline Dick Pacini
Hmmm.  I think I see a glow plug and a fuel line, so it runs on fuel and not sparks.  OK, how do you ever get your fingers in the nozzle to flip that little fan blade? LL~
AMA 62221
Offline RC Storick
Sense weight dont matter here's my idea.
Oh and by the way they guy who flies this is one brave soul!
Robert - Its not heavy at all ; Its only 13.9 oz complete. I also do not have to worry about adding anything else like prop, spinner, ect ect..
My Stalker 61 with tank weights 410 grams - Same as ts - So with 1.7kg of thrust vs - Not near that much its a no Brainer.
Online Paul Taylor
So PJ,
Show us the plane you have installed this in. S?P
Offline Dick Pacini
The gizmo on the scale is not the same as in his hand.  S?P
AMA 62221
Offline Bob Reeves
    • Somethin'Xtra Inc.
How Much $$$$$$
Offline ptg
Color choices??  Appearance points gotta get those appearance points!
PT Granderson
Offline RC Storick
One thing people forget is... How much fuel is that baby gonna use?
Offline PerttiMe
At least Jet A1 is cheap. But the weight of fuel...
Is the starter motor going to be a flying component or does it stay on the ground?
Offline John Witt
That's much smaller than I realized.  I've always wanted a scale F-86F.  That would be just right.
As for maneuverability, just vector the thrust.
How about an electric powered version of the external fan?  Plenty of room for experiments and fun.
John Witt
AMA 19892
Edmonds, WA
"Houston, Tranquillity Base here. The Eagle has landed."
Offline Dick Pacini
That turbine may be very light, but don't forget to factor in the weight of the flux capacitor. LL~
AMA 62221
Offline RC Storick
Fuel or battery is part of the total power package and must be considered
Offline PerttiMe
there are also very effective electric "turbine" fans now and they may be able to be governed.
But for those who want wet power for their ducted fans, Zero Displacement Engines are clearly the way of the future.
.. should be cheaper than turbines too, and doesn't need any electronics.
Offline John Cralley
Dang,
Ain't April 1st GREAT!!!!  y1 #^ LL~ VD~
John Cralley
AMA 52183
Central Illinois
Offline Garf
    • Hangar Flying
TURBOPROP sounds good to me. How small do they get?
Dwayne
That thing has to be Rusian!
Offline david beazley
Fuel consumption should not be a problem, just use a back pack mounted fuel tank, run the fuel line thru the handle out the lines to the engine.  Once the engine is running centrifugal (centripetal) [tomatoe/tomaato] force will feed it!
AMA # 2817
Uh, yea. Sure. Can't wait to see it in action.  ::)
Happy April Fools day Stunthangers :P
Thanks for all that info Bob - You were spot on with the " serious " part - This is first and foremost a Hobby ,one I take very seriously when in competition, but one I very much enjoy and have fun doing with friends.
The Nats will be serious for alot of us - but there is still room to crack a smile, enjoy a laugh with friends and be thankful everyday how lucky we are to be doing what we are doing.
Happy April Fools day :P
Offline Dick Pacini
Crap, you mean that was all a joke?  Dang!  I just bought a plane on ebarf that was said to have been designed for that little turbine.  Paid large for it.  HB~> Now I feel like such a chump.  Any chance you could sell me the one in the pictures?  I still have some money left. LL~
AMA 62221
PJ, while at the NATS, watch out for Windy and his water balloons I have heard about.  Some of the guys like to play mind games also.   Don't ask me how I know.  Main thing is to still keep having fun.   H^^
Offline Larry Cunningham
  • Red Hot Lover
  • Klaatu barada nikto my ass
    • Stephanie Miller
(I'm guessing they have April 1 down under as well.)
I have been looking forward to this, and here is my ideal subject for it:
L.
"There's an old saying in Tennessee - I know it's in Texas, probably in Tennessee - that says: Fool me once, shame on ((pause)) shame on you ((pause)) Fool me twice.. ((long, uncomfortable, agonizing pause)) you can't get fooled again!" - George W. Bush
Offline Douglas Ames
Sure it is...the exhaust nozzle has been removed, along with the ignitor lead.
AMA 656546
L.
That movie was pretty bad...
AMA 656546
