  • June 25, 2025, 05:49:34 AM
Author Topic: Half A ducted fan  (Read 1984 times)
Offline Dave Nyce
  • Flying
    • Revolution Sensor Company
Half A ducted fan
« on: January 02, 2023, 12:03:06 PM »
Does anyone know of plans for a half-A control line model that uses an electric ducted fan?
Dave Nyce   New Bern, NC
AMA: L356
Offline GallopingGhostler
Re: Half A ducted fan
« Reply #1 on: January 02, 2023, 12:40:34 PM »
Dave, both Hip Pocket Aeronautics and Outerzone have a 20" wingspan Harrier jet that uses an electric ducted fan. It can be either set up for RTP (round the pole, i.e. flown with a stick and single line to plane with no other control in a circle, or by standard control line.
http://www.outerzone.co.uk/plan_details.asp?ID=2954
It has an option to install a vane in the exit thrust airstream of the ducted unit, to provide vectored thrust. If coupled with the elevator, could provide action similar to ailerons.
Good luck.
« Reply #2 on: January 02, 2023, 06:04:40 PM »
Several on Outerzone for 1/2A that could be converted to electric:
https://outerzone.co.uk/advanced/search/results.asp?T1=CL&Y2=2022&K1=ducted&F1=Dscrp&K2=fan&F2=Dscrp
Mark
Offline Paul Wescott
« Reply #3 on: January 03, 2023, 03:10:13 PM »
As a stunter?  Or just to fly around flat and level?
Offline Dave Nyce
  • Flying
« Reply #4 on: February 16, 2023, 12:04:36 PM »
As a stunter.  Thanks for some ideas.
AMA: L356
« Reply #5 on: February 16, 2023, 12:12:31 PM »
I suspect you'd be disappointed in electric fans for stunting -- but it should be great for going in a circle fast.
I've been thinking of getting a larger RC ARF and converting it to 'lectric, just to get the complete package that Just Works so that I could go from there.  Then, when I knew what was what, rip the fans out and build something from scratch.  You could do the same thing with a smaller model -- figure out the ins and outs with something you don't mind demolishing, then build a nice one from the pieces.
« Reply #6 on: February 16, 2023, 01:47:41 PM »
Not long ago, someone was stunting with a pulse jet powered stunter. I was amazed at how well the power level was matched to the size and characteristics of the stunt plane.
Thinking outside the box, :! don't see why an electric ducted fan model couldn't perform the envelope, if properly matching its thrust to airframe. Perhaps something like the Jetco Saber stunter scaled down to half-A size and with ducted fan integrated to the fuselage just behind the wing?  D>K
« Reply #7 on: February 16, 2023, 02:11:35 PM »
Personally I like bigger planes, so I'd do something like a Skyray 35 with A-10-style nacells behind the wing and an extended nose to hold the batteries.
Your idea may do a better job of aligning the thrust with the CG - in fact, you may want to check out the Fan Trainer full scale. https://en.wikipedia.org/wiki/RFB_Fantrainer.
« Reply #8 on: February 16, 2023, 02:51:54 PM »
Personally I like bigger planes, so I'd do something like a Skyray 35 with A-10-style nacelles behind the wing and an extended nose to hold the batteries. Your idea may do a better job of aligning the thrust with the CG - in fact, you may want to check out the Fan Trainer full scale. https://en.wikipedia.org/wiki/RFB_Fantrainer.
As in all things, there are usually no ideal solutions, only compromises. Trying to fit battery and power unit in a manner to make it all work out in half-A size would be a definite challenge.
With the stunting Dynajet, thrust was out the back end and above. I think the OP wasn't interested in a contest quality stunt machine in half-A size, but something of builder's initiative that would be easy to build but a blast to fly.
Anyway, those are my initial thoughts. I haven't even given electric powered flight a thought yet, but that may change as we see our glow power resources dry up. D>K
« Reply #9 on: February 16, 2023, 06:02:11 PM »
Were the cutting edge of mighty scientic progress , at one stage .  %^@
Most of these would adapt . Saw a F2D on Ebay semi complete , once . One wonderes about the pointy bit , free flight .
Such Tecnology ! Dunno if this'd intrest you .
A pitcher is worf a fousand words .
https://www.hippocketaeronautics.com/hpa_forum/index.php?topic=17529.25
Youd get the bellcrank in the middle , on This One .
« Reply #10 on: February 16, 2023, 08:19:41 PM »
Veron Deltaceptor plan is available here: https://outerzone.co.uk/plan_details.asp?ID=11807
« Reply #11 on: February 18, 2023, 03:15:26 PM »
Yup.  That's a good part of why -- being lazy -- I'd start with an ARF!  That's all thought out and built.  As long as you can find a home for the bellcrank you're in like Flynn.
Offline Dave Nyce
  • Flying
« Reply #12 on: February 19, 2023, 10:44:44 AM »
Thanks for all the comments.  I think the Deltaceptor idea looks like a possibility.
AMA: L356
