  • July 25, 2025, 07:40:33 PM
Author Topic: Engine for Primary Force  (Read 4275 times)
Offline Mike Griffin
« on: August 05, 2016, 02:33:14 PM »
For all of you Primary Force folks out there, what size engines (GLO) are you guys using?  I am talking about Mike Pratt's original PF.
I have an Enya .30 I am thinking about using but would like to know what yall may have on yours.
Thank you
Offline Sean McEntee
Re: Engine for Primary Force
« Reply #1 on: August 05, 2016, 02:42:53 PM »
Many years ago I had the opportunity to fly one of Mike's own P-Force--I believe it was the prototype--and if memory serves, he had an 25 FP on it.  Flew REALLY well.  Anything in the .25-.30 size range should do the trick.
« Reply #2 on: August 05, 2016, 03:20:53 PM »
Thank you Sean
Offline Steve Scott
« Reply #3 on: August 05, 2016, 04:40:29 PM »
I asked Mike Pratt when he delivered my PF in person.  He said, "Fox 35 or OS LA 25 will fly it fine."  I assume that would include the OS FP 20.
He also offers drawings for an electric conversion.
« Reply #4 on: August 05, 2016, 06:03:30 PM »
Thank you Steve.
« Reply #5 on: August 05, 2016, 07:36:35 PM »
I have the SIG ARF Primary Force.
OS .35 on it.
Offline Brian Gardner
« Reply #6 on: August 05, 2016, 07:41:29 PM »
A question guys from a customer of mine.
EDIT, answer found with search function :P
« Last Edit: August 05, 2016, 08:02:21 PM by Brian Gardner »
Online Carl Cisneros
« Reply #7 on: August 05, 2016, 08:39:32 PM »
I use an OS LA46 on mine with APC 12-4 prop on 10% fuel.
Carl R Cisneros, Dist IV
Control Line RB
Offline Gary Mondry
« Reply #8 on: August 05, 2016, 08:42:27 PM »
OS 25FP on mine.  APC 10-4 on SIG 10%.  Flies it pretty well until the wind gets up.
AMA 10663
« Reply #9 on: August 05, 2016, 08:56:10 PM »
  I second the motion from Gary. I flew both the LA.25 and the FP.25 on mine, with giving the FP a slight edge on performance, using the same prop and fuel. I have since moved up to an OS.32 swinging a 11-4 APC Pro and LOVING it! I won quite a bit of hardware with mine, and it's on it's second covering job after the original stuff fell off. There are several threads on here about my exploits with the model. Still have it hanging ever at the ready in my garage along with a spare.
Offline Guy B Jr
« Reply #10 on: August 05, 2016, 11:06:15 PM »
Mike, check your e-mail.
Guy Blankinship
Offline Steve Thomas
« Reply #11 on: August 05, 2016, 11:35:05 PM »
Enya 30 would be a great choice.
Online Gordon Tarbell
« Reply #12 on: August 06, 2016, 12:00:13 AM »
I had excellent results using a Brodak 40 with bolly clubman 10.5x 4.5 prop. and home made chip muffler.  Hard to go wrong on this plane , it just flys great.
Gordon Tarbell AMA 15019
Offline MikeyPratt
« Reply #13 on: August 06, 2016, 08:24:52 AM »
Thank you
Mike,
There are many engines that work great on the P/F.  The Enye 30 should work just fine, is it the Enya a 30SS?  One of the most overlooked engine is the K&b 28 Sportster C/L engine.  The set up is really simple, bolt it on (after break-in) a 11x4" prop, 10% nitro, fly at 5.2 lap time, have a blast!!!
Later,
Mikey
« Reply #14 on: August 06, 2016, 09:21:10 AM »
Mike,
Later,
Mikey
Mike I sent you a PM
Offline Larry Fernandez
« Reply #15 on: August 06, 2016, 10:54:38 AM »
I ended up with a few Aero tiger .36's a couple of years back, so I stuck one on a Primary Force just for grins.
Larry, Buttafucco Stunt Team
« Last Edit: August 06, 2016, 11:46:42 AM by Larry Fernandez »
« Reply #16 on: August 06, 2016, 12:03:15 PM »
I built my PF from the short kit I got at VSC many years ago.  Started out with Fox .35 Stunt and it was a great combo.    Since it has been flown with a Brodak .25,  LA .25, and Fox .25.   The main engine is the LA .25 with 10-4 prop.  For some reason the Brodak .25 did not perform no matter what prop I used.  As Mikey says the little 30 should work great with the right prop for your area of the country. H^^
Offline Phil Spillman
« Reply #17 on: August 07, 2016, 04:22:52 PM »
Hi All, I have two of these great planes and they are flying really well on Evo .36 engines using 10 11 11 fuel with 10 X 6 props! This truly is a fun airplane to enjoy Sunday afternoons with!
Phil Spillman
Phil Spillman
Offline MikeyPratt
« Reply #18 on: August 08, 2016, 08:23:56 AM »
Hi Larry,
Without a dought, the AeroTiger 36 is a killer combo.  Jim Hoffman was really hard to beat with his.  Jim's P/F was only 36 ounces ready to go (from a short kit) and we flew it many times trying different props.  The 10.5 X 4.5 under cambered was the beat, a close second was 11 X 4 N 3 blade Bolly.
We had a BLAST with it.
Later,
Mikey
