  • July 17, 2025, 10:05:24 AM
Author Topic: Ultra Hobby Nobler  (Read 3160 times)
Offline big ron
Ultra Hobby Nobler
« on: February 03, 2015, 03:21:02 PM »
Just got a UHP Nobler was wondering about best engine options, tanks, any info will be appreciated
John Blanchard
Brusly, Louisiana
 AMA 1054488
Re: Ultra Hobby Nobler
« Reply #1 on: February 03, 2015, 03:23:55 PM »
An Aero tiger .36 is perfect.
BIG Bear
RNMM/AMM
Offline john gunn
« Reply #2 on: February 03, 2015, 04:29:11 PM »
 FOX super stunt 35,that is a good setup
Offline peabody
« Reply #3 on: February 03, 2015, 04:31:48 PM »
I only have two flights on mine....AeroTiger 36. Trying to figure a reasonable way to slow it some...
I may go and weigh it...it seems light.
« Reply #4 on: February 03, 2015, 06:39:47 PM »
This one of mine worked very well with an Aerotiger 36.  pretty light at 37 oz.
« Reply #5 on: February 03, 2015, 07:14:49 PM »
Hi Rich,
Maybe it needs a bit more 4 cycle?  what prop is on it?
Offline big ron
« Reply #6 on: February 03, 2015, 07:22:27 PM »
Rich did you silk span over the slc?
John Blanchard
Brusly, Louisiana
 AMA 1054488
Offline big ron
« Reply #7 on: February 03, 2015, 07:24:53 PM »
Randy how is yours finished? Can you paint over the self with epoxy?
John Blanchard
Brusly, Louisiana
 AMA 1054488
Offline Allen Goff
  • Charter Member
    • Fellowship of Christan modelers
« Reply #8 on: February 03, 2015, 07:29:39 PM »
I have a Brodak .40 in mine. How good did it fly? How about Steve Moon 1st, G. Nobler, Allen Goff 2nd, G. Nobler. Classic Stunt US Nationals. And the Aero Tiger .36 would be good also. By the way mine is 41 ozs. Both UHP kits.
Blessings
Allen
« Last Edit: February 04, 2015, 05:39:51 AM by Allen Goff »
« Reply #9 on: February 03, 2015, 07:59:16 PM »
Uhhhh...Sorry, I should have explained.  Mine is a UHP but built from one of their kits.  The wing and Stab/elevator are covered with Ultra kote and the fuselage is painted withTop Flite rattle can (not recommended for several reasons).  I built this in two weeks for VSC, three years ago,  after my Fury suffered a exploding bottle of CA that glued the cowling and bellcrank in place permanently.  I hate finishing airplanes some kind of castastrophie nearly always occurs in my finishing procedures.
The kit had great wood and built very nicely and quickly!  A really fine flying combination!
« Reply #10 on: February 03, 2015, 08:27:51 PM »
   Use less pitch!
Offline Mike Keville
« Reply #11 on: February 03, 2015, 08:34:59 PM »
   Use less pitch!
...or a Fox .35
(Flak jacket on here.)
« Reply #12 on: February 03, 2015, 08:59:37 PM »
...or a Fox .35
   A Fox would fly it pretty well, actually. This is a much better application than a Twister or other profile trainer that everybody seems to want to use. No match for the mighty Aero-Tiger, of course.
Online Robert Zambelli
« Reply #13 on: February 04, 2015, 06:33:51 AM »
Mike wrote:  "...or a Fox .35"
Mike - a Fox 35 in a Nobler? Has it ever been done before?  ???
Offline SteveMoon
    • www.ultrahobbyproducts.com
« Reply #14 on: February 04, 2015, 10:04:54 AM »
Big Ron: Brodak 40, OS 40 LA, Thunder Tiger 36, AeroTiger 36, Fox 35. Any
of these will work just fine. You can paint the covering directly. Although,
I would recommend using auto paint rather than dope. Just scuff the
entire surface with 600-800 grit paper first.
Offline Allen Goff
  • Charter Member
« Reply #15 on: February 04, 2015, 11:26:11 AM »
Steve, I sure would like to build a nether UHP kit. I am going to retire my signed G. Nobler. How about one?
Blessings
Allen
« Reply #16 on: February 04, 2015, 02:23:19 PM »
  Since it already has a far superior engine, and only needs the pitch reduced, not much reason to go backwards. The problem he is having is extremely simple, no need to go digging the motor mounts out.
Offline SteveMoon
« Reply #17 on: February 05, 2015, 08:34:04 AM »
Allen: We haven't had any laser cut kits in quite awhile. But, I may
be able to get my hands on one that isn't going to get built in the
near future.
Offline Allen Goff
  • Charter Member
« Reply #18 on: February 05, 2015, 11:11:05 AM »
Steve, I'm interested. Will you be in Toledo for the Expo Fri.?
Blessings
Allen
« Reply #19 on: February 05, 2015, 01:55:35 PM »
I just want to get my Ultra Hobby laser cut BEAR kit built! LL ~  LL~   LL~  LL~   H^^
(it looks gorgeous in the box! ;D )
BIG Bear
RNMM/AMM
