  • July 04, 2025, 03:42:19 AM
Author Topic: Take apart connection  (Read 1505 times)
Offline Larry Wong
« on: August 14, 2012, 05:51:02 AM »
What are some of the ways to connect the lead out to belcrank.  and prevent them from dropping in the wing when disconnected.  HB~> HB~> HB~>
Larry
Re: Take apart connection
« Reply #1 on: August 14, 2012, 05:57:43 AM »
Yellow inner Ny-rod in the wing? ;D
« Reply #2 on: August 14, 2012, 06:11:51 AM »
I use line clips just like we use to hook that lines to the leadouts. When I take the wing off I connect the line clips at both ends (the inside and outside of the wing) this forms a continuous loop that cannot drop into the wing. That being said, I have become pretty good at fishing leadouts out of the inside of the wing... HB~>
Derek
« Reply #3 on: August 14, 2012, 09:18:58 AM »
Of course, you could always stuff foam or cotton in the wing so they wont drop out of sight, then take it out upon re-assembly.
« Reply #4 on: August 14, 2012, 02:05:35 PM »
go to a dollar store and buy some of the cheap spring clamps - (you only really need one)  after you undo your wing - put the clamps on the leadouts - unhooked from bellcrank - then join the loops together and remove clamps.
Offline Larry Wong
« Reply #5 on: August 14, 2012, 02:06:23 PM »
Derek YES  been there, done that,  now do you hook right to the belcrank, or do you add a connector to the belcrank then hook with a clip, or is the lead hook to a belcrank clip.. I think I got that right!   ~^ ~^ HB~>
Larry
Offline Dallas Hanna
« Reply #6 on: August 15, 2012, 12:59:14 AM »
Another simple way.  Wire clip with 0.027" wire leadout bound, epoxied etc covered with heat shrink.
HH
Offline Larry Fernandez
« Reply #7 on: August 16, 2012, 11:11:22 AM »
Who sells the hardware for this type of take apart system??
Larry, Buttafucco Stunt Team
« Reply #8 on: August 16, 2012, 11:56:11 AM »
I hook the connector directly to the belcrank.
Larry, Dallas Hanna sells that take apart hardware
Derek
Offline Norvaldo
Norvald Olsvold
