  • July 15, 2025, 01:23:40 PM
Author Topic: Surgical tubing in tank - how long will it last?  (Read 5548 times)
« on: July 13, 2012, 10:09:52 PM »
Guys,
I'm looking to use a smaller plastic tank that I want to set up for uniflow. Problem is that even with the Sullivan silicon tubing it doesn't flop smoothly in the smaller length tanks. I know that surgical tubing is very flexable and will work but don't know how it will hold up inside the tank. Anyone use surgical tubing inside a plastic tank? How long does it hold up till you need to change it out?
Best,        DennisT
Offline Steve Scott
Re: Surgical tubing in tank - how long will it last?
« Reply #1 on: July 13, 2012, 10:35:44 PM »
It melts down pretty quickly - perhaps in about a week.  Or less.
« Reply #2 on: July 14, 2012, 10:10:37 AM »
Have you considered a balloon tank.   I have been playing with them on the bench for the 1/2A's.   Just no room in the little 1//2A Snapper for the balloons I can get.  Also very consistant needle settings on the bench. H^^
« Reply #3 on: July 14, 2012, 10:51:42 AM »
Check out the FF supply houses.  The will have thin walled silicon tubing in different diameters that might work for you.
One place is Texas timers at:
http://www.texastimers.com/
Another is Doug Galbaith's Model Airplane Stuff  (some really neat things here):
http://www.the-printer.net/DookCat.html#Nelson%20engine
Just Google Free Flight Supply and you will find all sorts of stuff.
Some of this thin walled silicon tubing will have a service life in a high nitro environment, but will certainly last longer than any surgical tubing option.
Offline dirty dan
« Reply #4 on: July 14, 2012, 11:15:29 AM »
Pay no attention to the Nervous Nellies urging you to avoid surgical tubing in a fuel tank.
I can tell you without hesitation that virtually any kind of such tubing will easily last until the day of the next contest.
Dan
Dan Rutherford
« Reply #5 on: July 16, 2012, 07:51:41 PM »
Looks like this was done by Al Rabe did this for the BBFB Bearcat and Critical Mass models. Attached is a photo.
Best,           DennisT
« Reply #6 on: July 16, 2012, 08:39:42 PM »
the clunk does not need to "flop around"
during flight, the forces applied to it will make it move where required.
« Reply #7 on: July 16, 2012, 09:15:35 PM »
Within reason.
Offline John Lindberg
« Reply #8 on: July 17, 2012, 06:51:09 AM »
Keith is right, the thin-walled silicone tubing is great, check out those suppliers, FAI Model Supply was sold recently, another source for FF stuff, hope he keeps the line going.
« Reply #10 on: July 18, 2012, 03:19:07 AM »
Best,           DennisT
So how did Al close out the tank?
He didn't solder it with the flex tubing inside?  Did he?
« Reply #11 on: July 18, 2012, 09:26:53 AM »
Yes, several people do that.  H^^
Offline Don Curry AMA 267060
« Reply #12 on: July 18, 2012, 09:33:51 AM »
I have done that with the flex tube inside the metal tank and it works fine. But it is easier to use a plastic thank and the result is the same.
Don
« Reply #13 on: July 18, 2012, 09:57:23 AM »
Don,
Normally I would use the plastic tank, it's lighter and ready to go quicker but in some ships there is not enough room for the size the offer (i.e. 3oz) and you need something that fits the available space. With the metal tank you can get the size you need. It looks like as long as you use thin walled silicon tubing it should work for several seasons.
Best,  DennisT
Offline bob whitney
« Reply #14 on: July 21, 2012, 03:33:19 PM »
Dennis , give me a call  B Whitney
rad racer
Tags: tank
