  • June 20, 2025, 05:56:03 PM
Author Topic: 2 holes about 120 degrees off???  (Read 1560 times)
Online Paul Taylor
« on: July 19, 2012, 08:02:42 PM »
One of my flying buddies got a LA 46 with a PA type NVA in it. He had to pull it out and swap ends cause it was going on a profile so the needle would be on top. When he pulled it he said it had two holes in it about 120 degrees off when both holes pointing downward.
I have seen some with two holes 180 degrees out but not 120. I have never heard of this one.
Anyone every seen this type of NVA?
Re: 2 holes about 120 degrees off???
« Reply #1 on: July 19, 2012, 08:05:46 PM »
Maybe it is an improvement over the old Fox way of doing it. H^^
« Reply #2 on: July 19, 2012, 08:15:38 PM »
HI Paul,
I have never seen any of Randy's NVA with two holes. ???  (maybe his Fox stainless steel one, I can't remember)  Does/did the Brodak NVA have 2 holes?
You got me.........
BIG Bear
RNMM/AMM
Offline rustler
« Reply #3 on: July 20, 2012, 03:00:35 PM »
Possibly copied from some PAW engines?
Ian Russell.
Offline Allan Perret
  • Proverbs
« Reply #4 on: July 21, 2012, 03:05:48 PM »
Never seen that, but I would expect that configuration to have better draw than the 2 holes at 180°.
Allan Perret
AMA 302406
Slidell, Louisiana
