  • August 02, 2025, 05:54:03 AM
Author Topic: Skyray my way...  (Read 1803 times)
Skyray my way...
« on: October 05, 2006, 07:12:10 PM »
Well folks, here is one of my current projects. It is/was a Skyray with all new, respaced, balsa ribs and built-up wingtips, fixed, tapered flaps yielding a 47" overall span and 500 sq. in area (stock is 396 sq. in.). Adjustable leadouts and an outboard trim tab are also added. I also added a balsa 3/8" x 3/8" triangular stiffener along the top and bottom of the fuse, and made a new inboard ply doubler, sans engine cutout. The new 3/16" stab and 1/8" elevator has a 19" span at the hinge line. Stock was much smaller. Sig Fazer aluminum L/G was also added. Power was going to be a Fox .35, but I have since come to my senses and will now be fitting an O.S..35S. Hopefully I can get the pics loaded here, and you can check her out! ;D
Offline Leester
Re: Skyray my way...
« Reply #1 on: October 05, 2006, 07:28:37 PM »
That looks good, nice job. How you going to finish it??
Leester
ama 830538
« Reply #2 on: October 05, 2006, 07:37:51 PM »
Very Nice.
Do you think it would fly better with flaps?
My Ray done my way, and redone, and redone.
Now sporting a new OS .25, and in search of the right prop.
I like my Ray
« Reply #3 on: October 05, 2006, 07:41:50 PM »
It'll be an all grey 60's type U.S. Navy scheme with all the markings, maybe even with a white belly.
Flaps might help, but hey, it's a Skyray. ;)
Offline Ken Deboy
    • Silk and Dope
« Reply #4 on: October 05, 2006, 08:59:36 PM »
Nice looking Skyray. Hope you'll post more pics when it's finished. About the Fox... nothing wrong with a Stunt 35 that can't be fixed by a going over by Larry Foster:)
cheers,
There is a fine line between "hobby" and "mental illness"
« Reply #5 on: October 07, 2006, 07:28:15 PM »
 Not completely ripping on the Fox, there is surely thousands of great running ones out there, heck, I even have one that falls into that category on another model. However, the other 50th anniversary one I've got isn't even broken in yet, (2 three ounce tanks of fuel so far is all) and may need to get some massaging done, it's REALLY tight. ;D
Offline Harleyman
  • ACE
    • Circle Masters
« Reply #6 on: October 08, 2006, 09:25:23 AM »
Can't wait to see it.  Please, post more pics as it progresses.
Chris Sterner
AMA 1825
EAA 1429853
https://circlemasters.com
