I think one major project gets waylaid by a new one. I have attempted to promise myself to finish what I have on the table before going to another project. I put my Do-335 vertically between the TV stand and the Stereo stand for safekeeping in our living room. There was only enough room to put the model nose down and the vertical rudders and landing gear just barely fit between the two pieces of living room furniture. Safe, heh? Lo and behold, the clock on the wall fell down and found the cavity between the two furniture pieces and took off the lower rudder on the Do-335 and tore up the bottom of the fuse. I am fixing that right now and will return to the Oriental within a few days.
Thus the Oriental is the only model on the plate after the repair of the Do-335. My kind of to-do list is as follows: Oriental, then on to build my own Plano for the VSC next March, then to a new Humongous with Fox 59 power for the Nats next year. After that, I plan to continue on the path to take a Randy Smith foam Vectra/Dreadnought which he qualified with so many years and turn it into a Trianic clone and powered by a PA .61 pipe. It will be an SV-41 Triumph, of which I will not publish or kit, but advertise as a Randy model.
