General control line discussion => Open Forum => Topic started by: Allen Brickhaus on June 05, 2011, 04:00:17 PM
This model has not taken as long as the Do-335 but it is about ten years since I have worked on my Oriental. With the MonoKote green and primer on the body, flaps, stab and elevators, the current all up weight is at 38 ounces. The Oriental will house a special Larry Foster ceramic Fox 35, a Magnum type 4.5 ounce tank and all but wingtip weight and final paint.
The Oriental prior to primer.
The tank compartment and engine area.
Sitting on the deck with the L&J Fox 35 installed.
Installing the small leather fillets on the bottom of the Oriental.
Top fillet work with small leather type.
The fillet area has a light coat of spackling compound on the adjoining area.
Allen. Be very careful. Leather fillets adhere to dope well, but any hint of spackling compound and the dope will "lift". I have learned never to use anything but epoxy around fillets. Even then, special care must be taken to remove any surface wax from the epoxy.
Good Luck with the Oriental
Is that an original Froom spinner?
The model looks like it is shaping up very nicely!
Appreciate the concern, but I have not used dope since the summer of 1974 when I first returned from Army duty in Germany. All my publications have concerned the use of iron on films and either Rustoleum, X-O Rust, X-Stop or Formula U as a painting process. My last Stuntwagon finishing technique was used as a back page a a page or two in a recent Stunt News. I find no problem with these paints over the leather fillets. If one does use dope, then heed Floyd's concerns.
Allen Brickhaus
The spinner is an original Veco, as I still have the box it came in. Good eyes Steve.
Allen Brickhaus
Its always interesting to understand why people take the time to start a project / get it to a certain point, then abandon it without taking it to completion.
Im guilty of this - in 2005 Built 2 ships identical one was lighter by 2 oz - so the other was put aside with only the finish needing to be applied. I eventually finished it - 3 planes and 4 years later....... Given circumstances these days - I would elect to knock it over - finish it - test fly it and put it away ( if it was never goign to be a comp spec model )
I have also taken possession of a fellow fliers - model that was 18 yrs old in bare bones, and finished it off. - Seems a waste to have models sitting there.
Nice work Allan on the build.
thank you, hoping for a 43 ounce bird ready to fly.
Allen
Looks good Allen.
Hope to see it at the MSC.
L8r
It only took me 9 years to finish a Profile Cavalier kit by Tom Morris! #^
I think one major project gets waylaid by a new one. I have attempted to promise myself to finish what I have on the table before going to another project. I put my Do-335 vertically between the TV stand and the Stereo stand for safekeeping in our living room. There was only enough room to put the model nose down and the vertical rudders and landing gear just barely fit between the two pieces of living room furniture. Safe, heh? Lo and behold, the clock on the wall fell down and found the cavity between the two furniture pieces and took off the lower rudder on the Do-335 and tore up the bottom of the fuse. I am fixing that right now and will return to the Oriental within a few days.
Thus the Oriental is the only model on the plate after the repair of the Do-335. My kind of to-do list is as follows: Oriental, then on to build my own Plano for the VSC next March, then to a new Humongous with Fox 59 power for the Nats next year. After that, I plan to continue on the path to take a Randy Smith foam Vectra/Dreadnought which he qualified with so many years and turn it into a Trianic clone and powered by a PA .61 pipe. It will be an SV-41 Triumph, of which I will not publish or kit, but advertise as a Randy model.
Then to look like the Trianic.
Allen,
As nice as the Olympus is, I always liked the look of the Trianic (one of your better looking ships in my opinion).
James
Thank you,
Allen
sheeeeew........thems some purty planes! can't wait to see the Oriental finished! H^^
On my way home from the Brodak Fly In and hope to get to work on the Oriental again.
Allen Brickhaus
Wish I could have made it up to Brodaks Allen. You and Tom do a great job running it. Hope you see you in August.
Now I don't feel too bad taking waaaay too long to get my Vector done. :)!
Thank you, come to the Western Kentucky/Southern Illinois Stunt Champs in Paducah on August 20 and 21.
Allen
