  • June 20, 2025, 09:50:10 AM
Author Topic: Skyray 35  (Read 1767 times)
Offline David_Ruff
  • David Ruff
  • Retired Army
Skyray 35
« on: December 27, 2023, 12:25:52 PM »
In progress...
Just glad to be here
Online Bill Morell
Re: Skyray 35
« Reply #1 on: December 28, 2023, 08:41:36 AM »
Looks good! Going with the FP 20?
Bill Morell
Vietnam 72-73
Offline David_Ruff
  • David Ruff
  • Retired Army
Re: Skyray 35
« Reply #2 on: December 28, 2023, 08:46:05 AM »
Fox .35
Offline David_Ruff
  • David Ruff
  • Retired Army
Re: Skyray 35
« Reply #3 on: December 28, 2023, 10:28:03 AM »
Maybe this will help
Offline Colin McRae
  • Are we having fun yet??
Re: Skyray 35
« Reply #4 on: December 28, 2023, 11:34:53 AM »
Hopefully your single center landing gear wheel will be Ok for you at your flying field.
I originally had a single wheel on a Flite Streak. Our CL field is a bit bumpy, and I kept tearing the covering underside of the outer wing on routine landings when the wing tip would drag. I eventually changed it out to 2-wheel gear. I did the same on my new Skyray 35 build. I made up some simple aluminum gear for the Skyray.
Offline David_Ruff
  • David Ruff
  • Retired Army
Re: Skyray 35
« Reply #5 on: December 28, 2023, 11:54:58 AM »
Yes.  I thought about it for a while and went with the stock LG.  I can always put a skid on the outer wingtip.  I mostly plan to fly it from grass areas.
Offline David_Ruff
  • David Ruff
  • Retired Army
Re: Skyray 35
« Reply #6 on: December 28, 2023, 11:56:13 AM »
What did you finish the fuselage with?  I am using the Ultracote on the wing and as you see, the tail surfaces.
Offline Colin McRae
Re: Skyray 35
« Reply #7 on: December 28, 2023, 12:39:14 PM »
My wing uses Monocote. All the other surfaces are Brodak butyrate dope. I am a rookie builder and can't do 'perfect' finishes. I brushed on the dope color, then a flying buddy of mine let me use his spray equipment for a final clear coat (also dope).
Dennis Leonhardi
Re: Skyray 35
« Reply #8 on: December 28, 2023, 01:43:08 PM »
Good job, it looks great Colin.
Dennis
Offline Colin McRae
Re: Skyray 35
« Reply #9 on: December 28, 2023, 02:05:18 PM »
Dennis
Thanks Dennis, and it flies great too thanks to a few modifications suggested by Brett Buck. And the OS 25 LA engine doesn't miss a beat.
Offline bill bischoff
Re: Skyray 35
« Reply #10 on: December 28, 2023, 06:07:15 PM »
Make sure you get the leading edge well rounded.
Re: Skyray 35
« Reply #11 on: December 29, 2023, 12:06:22 AM »
     Good eye, that could use some more work. There is a LE carving template in the kit, it should be AT LEAST as blunt as that. If you lost it, use the plans to make a new one. With a Fox, you are going to need that wing to work as well as it possibly can. Making it more blunt also reduces the criticality of getting it exactly symmetrical.
    BTW, reviewing the plans, I would mildly disagree with Mikey's recommendation of a knife and sanding block to shape the LE.  If you have one, a razor plane or block plane will be a lot easier to control and keep the LE straight. I use the little Master Airscrew plane, or a very small wooden Japanese block plane. I do the majority of the shaping with the plane, taking a series of flat cuts, then just merge them with the sanding block. That will keep you from scooping it out in the middle. Put tape across the ribs just behind it to warn you when you are getting too close.
