  • July 05, 2025, 01:40:57 PM
Author Topic: Steve Hand/ Exemplary stunt planes  (Read 2202 times)
Online Gordon Tarbell
« on: April 23, 2008, 06:46:01 PM »
Are these kits still available or plans or short kits? I tried the email shown in the Brodak #15 cat.  and my attempt was bounced back to me. These were four really nice looking kits. I really liked the China Clipper and the Sky Writer.
Gordon Tarbell AMA 15019
Offline BYU
Re: Steve Hand/ Exemplary stunt planes
« Reply #1 on: April 23, 2008, 07:59:26 PM »
Hi
I have a China Clipper - Brand New untouched, cost me 220 plus shipping. Yours for 200 all in.
Just need your address and monies.
Eliott
« Reply #2 on: April 23, 2008, 09:10:21 PM »
I have the Skywriter plans I can send you also
« Reply #3 on: April 24, 2008, 09:12:29 AM »
AFAIK, Steve is still a member here.  I will look, myself, soon, but a look through the membership list should provide accurate contact information.  The list is generally in alphabetical order, but can be altered to you wishes with the click of a button.
« Reply #4 on: April 24, 2008, 09:14:05 AM »
Hi Gordon,
Did you use this email??
mollycarl *at* yahoo *dot* com
Online Mike Scholtes
« Reply #5 on: April 24, 2008, 10:55:26 AM »
I have an unbuilt China Clipper kit (which I intend to keep) that I got a few months ago. The problem is that Kyle Tankersley, who cuts the kits for Steve, has apparently given up the business and Steve is without a cutter. Mine is very high quality and if you can get a kit, go for it. Steve has plans, as does Claus Maikis (China Clipper designer). If all else fails I can make you a copy of the CC plans.
« Reply #6 on: April 24, 2008, 09:34:57 PM »
Bill, I used the email address that is listed in Brodak #15 catalogue.  I am buying the kit(China Clipper) from eliott. There are others such as the Sky Writer that I really like also.  I will try to email Steve at the address you gave here Bill, thanks. Now I need to decide which engine to power it with. I have a double star lite ring that is needing some exercise, or maybe put together a Vcase ST 60 using the Brian Gardner ABC P/L set I have been saving.
Offline Geoff Goodworth
« Reply #7 on: April 24, 2008, 09:44:12 PM »
Steve's work was all done by Kyle and on the U-2 that I bought, it is outstanding.
If Kyle's email is still working, talk to him about current stock. There was some at Kyle's when I last spoke to him a couple of months ago.
Good luck, Geoff
« Reply #8 on: April 25, 2008, 07:35:15 AM »
Hi Gordon,
I would say that either of those engine would be a good choice from what I remember about those planes.  The choices could be dependent on the balance you anticipate.  With the weight difference that might be the sole deciding factor.  I am pretty sure the ST is *stronger*, but I don't think the DS would suffer at all.
Geez. not sure I made a LOT of sense there........... LL~  (I think you know what I mean! LL~ LL~ )
Bill <><
« Reply #9 on: April 25, 2008, 07:42:31 AM »
Good luck, Geoff
Hi Geoff!
How's it going??
As to Kyle, I know he announced that he was stopping since he was using Riley for his wood and it was local, AFAIK.  BUT!  I believe, (will have to check!) that he will cut if you supply the wood.  I'm about 100% positive he has not gotten rid of his laser cutter.  It would be worth a check.
We also have Laser Works in the Vendor's corner.  Eddie is absolutely great, too, with his cutting and service!  I say he's right up there with Kyle.   Eric Rule at RSM cuts special projects, and Pat Johnston/Dee Rice are beginning in the business.  What they are offering is also outstanding!  It is also my understanding that Brodak will laser cut?? I am not 100% sure on that one.
One thing is positive, I know I will NEVER stack cut a set of "C" or "D" tube ribs, ever again!
(The only difference I have seen is that Kyle was 40%-50% less expensive than the others last time I was dealing with him.)
Bill <><
Offline Kerry Ewart
« Reply #10 on: April 26, 2008, 04:11:43 PM »
If you check out Kyle's site this is what he says.
     "Due to lack of reasonable wood stock prices I have quit laser cutting custom work airframes from balsa and ply.  I anticipate getting back into it in a few years from now.        I will cut replacement parts for existing customers, cut or re-cut kits of existing artwork on file, but will not be taking on new design or drawing projects without a guarantee of at least 25 kits to be made and stock to be supplied. Ask for details.
     I am offering Rabe Control line model kit cutting and parts, but stock will need to be supplied.  Ask for details. "
So basically it is a "You want it you supply the wood" situation as for Steve Hand/ Exemplary stunt planes you will have to contact Steve him self for any more details.
I have a "Skywriter" kit and it is first rate.
"If you cannot beat them!JOIN THEM.
