  • July 22, 2025, 11:31:33 AM
Author Topic: Stay Clean Fuel Jug  (Read 1569 times)
Offline Jerry Reider
Stay Clean Fuel Jug
« on: May 11, 2009, 09:42:03 PM »
I found a way to keep dirt out of my fuel at the flying field.  I measured the diameter of my fuel line at .220".  So I drilled two .200 diameter holes in the cap of my gallon fuel jug.  I put a long piece that reaches to the bottom of the jug in one hole and a 1" long piece for a vent in the other hole.  I cut angles on the end of the tubing so it was easier to push through the smaller diameter holes in the cap.  I also used different colors of fuel line so I know which is the vent.  I accidently found that since the cap is one of those stupid child proof caps that I can turn it 1/8 of a turn and it seals both tubes shut for storage.  It took about 5 minutes to do.
Jerry
Re: Stay Clean Fuel Jug
« Reply #1 on: May 11, 2009, 09:52:24 PM »
http://www.amazon.com/Kwik-Fill-Fuel-Can-Fitting/dp/B0006NATH0
« Reply #2 on: May 11, 2009, 10:50:31 PM »
there are numerous "off the shelf" variations to this - but I guess you can claim builder points on this one  <=
