  • July 04, 2025, 03:04:14 PM
Author Topic: AMA co-sponsoring GoFly  (Read 718 times)
Offline david beazley
« on: December 07, 2017, 02:16:24 PM »
Has anyone else seen this?
http://amablog.modelaircraft.org/amaeducation/2017/12/05/ama-supporting-gofly-flight-competition/#respond
AMA in there inimitable wisdom is now co-sponsoring, along with Boeing the GoFly competition. The goal is a "safe", quiet person carrying (I guess it's not PC to say man carrying ) personal flying thingy that has a 20 mile range.  I wonder what's in the water in Muncie?  This from the same bunch that are courting drone pilots. (How's that working out for you, AMA?). I tried to leave a courteous dissenting viewpoint but looks like it didn't make it. Also on AMA's homepage there is a statement about FAA registration is likely to return. Wasn't there a lengthy article in MA on how well AMA represents our interests wit the Feds?  Maybe it's just me...
AMA # 2817
Re: AMA co-sponsoring GoFly
« Reply #1 on: December 07, 2017, 08:09:25 PM »
I left a comment "How is this model aviation?"
Not sure if they posted it.  Not worth the effort to check...
Offline Al Ferraro
« Reply #2 on: December 08, 2017, 07:50:22 AM »
Read down further, not for CL.
Al
Q: Do only drones and multirotor operators need to register?
A: No. Anyone who flies a model that is over 0.55 lbs (or 250 grams) and uses a ground-control system with a communications link, such as an RC transmitter, is required to register. If you exclusively fly models under .55 pounds, indoors, CL, or FF - you do not need to register.
