  • July 17, 2025, 10:41:18 PM
Author Topic: Spot Repair Putty  (Read 2660 times)
Online James Mills
Spot Repair Putty
« on: March 04, 2007, 02:04:10 PM »
What are you guys using to take care of small dings and the like during the primer coats?  I have some stuff made by 3M (same stuff Windy used on some of his past videos, green in color).  I think my tube is to old to use, doesn't want to stick when spreading and hard to sand so I'm going to need to pick something up.
James <=
AMA 491167
Re: Spot Repair Putty
« Reply #1 on: March 04, 2007, 02:25:22 PM »
Bondo makes a red spot putty that costs about $3 at Wally World.  It works pretty much the same as the 3M.  It's in the automotive section.
FORGOT TO ADD:  you can add some acetone to the green putty and use it for short term.  It dries out (looses it's carrier), but the acetone will reactivate it until you can get some more.  I have also used lacquer thinner for the same purpose.
Offline Bob Disharoon
« Reply #2 on: March 04, 2007, 03:27:45 PM »
I agree with Bill..the red bondo is good stuff...cheap, dont have to mix it very precisely, and it "kicks" in 5 or 10 min.   easy to work and sands easily..I used to use it on fiberglass and gelcoat for boat repairs..good luck, BOB
« Reply #3 on: March 04, 2007, 05:00:47 PM »
AND:  Bondo also has a small tube of glazing putty that doesn't need mixing.  I use all kinds of stuff as long as it works and isn't too heavy!
Mix micro ballons with Elmer's Glue All, balsa sanding dust with Ambroid, or white glue, etc., etc.,
« Reply #4 on: March 04, 2007, 06:33:10 PM »
I use Elmer's Carpenter's Finishing Wood Filler for light woods. It is a latex based light filler that is a little more yellow than balsa. It goes on very easy, sticks like glue, and is very easy to sand. It can be feather edged with a finger dipped in water, is light weight, and works well under translucent yellow dope finishes. I like it!
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
« Reply #5 on: March 04, 2007, 08:56:28 PM »
It's what I use too, but I always hesitate to mention it for fear of giving someone on the board a heart attack...
--Ray
--Ray
AMA902472
Online Crist Rigotti
« Reply #6 on: March 04, 2007, 09:04:02 PM »
James,
During the primer coats I use Bondo brand glazing putty.  It has a reddish color to it.  Wet sands very easily and feathers real well too.
« Reply #7 on: March 04, 2007, 09:06:07 PM »
Be careful of the spot putty. The stuff never stops shrinking. OK for very light scratches and such, but it will crack eventurally if used in too large an area. I use a catalzyed spot putter called glazing compound (I use soem stuff called Dolphin Glaze). Works and sands pretty much like the old spot putty, but it's catalyzed so, once it cures, that'ts it. What you have is what you have. No concerns about shrinkage.
« Reply #8 on: March 05, 2007, 02:41:16 PM »
Good reccomendation Randy. another benefit of catalyzed glaze, it is fairly inert to solvents. With the one part glaze, whenever you spray laquer,(dope) on it, it will swell and then reshrink, not a good thing for that peachy pretty finish.
« Reply #9 on: March 05, 2007, 08:45:39 PM »
Hi RAndy,
I use Eurosoft two part glaze for large areas.
Bill <><
Offline steve pagano
« Reply #10 on: March 05, 2007, 09:32:03 PM »
Is this stuff strong enough for fillets? I've herd of some people using some kind of fill thats blue any one herd of it ?
Success isn't a destination.It's a journey!!!!!
A.M.A. 820-823
