Brett,
The only thing I don't like about this handle design is if you're lines are almost exactly the same lenght, then you have to adjust the thing, sliding the bars in or out. I feel this introduces bias in the handle not really different from the forward cant (though it may be bacward I guess. I feel like the pivot the lines work off of needs to be perpendicular to the ground (square to the bellcrank). If it's slanted (and sliding the adjuster in or out introduces a slant) can, at least in my opinion, introduce a slant in referrence to the bellcrank. Granted, if your lines are pretty much exactly the same lenght, it's a moot point since the adjusting bars will be the same. But if not ...
