  • June 20, 2025, 08:07:51 PM
Author Topic: OK Cub 09  (Read 624 times)
Offline Bill Morell
OK Cub 09
« on: August 04, 2022, 12:18:35 PM »
Not very familiar with these. Is the spray bar a press fit and if so what is the best way to remove it?
Bill Morell
Vietnam 72-73
Offline kenneth cook
Re: OK Cub 09
« Reply #1 on: August 04, 2022, 01:57:08 PM »
          Bill it is pressed in. I set it up in my drill press and I used a piece of round steel chucked up to push it out. Personally, I remove the spraybars from Cox production backplates ( Plastic versions) and I put them in the Cubs with a little JB weld around it to hold it. Works superior to the OK needle which is terrible.
Offline Bill Morell
Re: OK Cub 09
« Reply #2 on: August 04, 2022, 02:22:59 PM »
Thanks Kenneth! That sounds doable.
Bill Morell
Vietnam 72-73
