  • June 26, 2025, 07:11:29 AM
Author Topic: Some Thundergazer Progress  (Read 4126 times)
Offline Matt Colan
« on: February 10, 2012, 08:34:54 PM »
So here is the plane that we were planning on making a trip to Bulgaria with and what it looks like now.  The plane currently weighs 22.5 ounces, and I'm happy with that.  The stab and elevators are completed and weigh 2.5 ounces minus the control horn.
After these pictures were taken, we molded the wood for the fuselage, so that should come together fairly quickly.
Oh and I'm powering it with a Brett Buck RO-Jett 61
Mike Griffin
Re: Some Thundergazer Progress
« Reply #1 on: February 10, 2012, 09:47:27 PM »
Looking really good Matt.  When you finish it I would love to have some pictures of it to feature in my photo gallery...
« Reply #2 on: February 10, 2012, 10:26:00 PM »
Looking good kido.
Is there no front Firewall ?
Below is mine as an example.
« Last Edit: February 10, 2012, 10:46:57 PM by PJ Rowland »
Online Dallas Hanna
« Reply #3 on: February 11, 2012, 05:00:35 AM »
Looking good Matt!  Pics came through on mail ok today.
HH
Offline louie klein
« Reply #4 on: February 11, 2012, 08:01:44 AM »
That's gonna be sweet!---LOUIE   y1 H^^ D>K
Offline Matt Colan
« Reply #5 on: February 11, 2012, 09:21:00 AM »
Looking good kido.
Hi PJ,
It was there, but when we went to go see where the tank would be, we had to grind most of it away.  There will be more added into the engine bay of the fuselage when we begin working on it.
John Leidle
« Reply #6 on: February 11, 2012, 09:42:41 AM »
  Hey Matt,  if you want to know Eddie Rickenbacker a little better find & read the book about him & 7 others in a plane crash.  It's called
                  We Thought We Heard The Angels Sing"
  I suggest this you might have trouble finding it but you wont be disappointed.
  john
Offline Matt Colan
« Reply #7 on: February 11, 2012, 04:38:16 PM »
Hi Mike,
Sure, I'd be glad to send you some pics for the photo gallery!  H^^
« Reply #8 on: February 11, 2012, 06:56:58 PM »
Looking good anyway - as always if u need a hand give us a shout.
Mike Griffin
« Reply #9 on: February 11, 2012, 06:58:30 PM »
Thank you Matt
Offline Matt Colan
« Reply #10 on: February 11, 2012, 11:01:38 PM »
We got the wood out of the molds tonight and they came out pretty good.  This is the easiest way we've gotten top and bottom blocks on.  We didn't glue them in place but the formers are in.  The only problem was the mold for the top block warped and we didn't know until I noticed the warp.  So we cut off the plywood back and are going to gouge a straight one on the mold and try to re-wrap the wood to get the warp out.
« Reply #11 on: February 12, 2012, 04:28:13 PM »
Looking good so far, Matt.  This should be a good one for you! y1
BIG Bear
RNMM/AMM
« Reply #12 on: February 14, 2012, 03:52:04 AM »
ROCK ON MATT!!!!!!!! 8)
Derek
Offline John Lindberg
« Reply #13 on: February 16, 2012, 11:12:41 AM »
Is this fom the RSM kit? Does the kit come with the warren-truss angled wing rib design? Looks good!
« Reply #14 on: February 16, 2012, 11:20:11 AM »
Looking good kido.
 I generally don't use that sort of firewall because I slide the tank in from the front.
« Reply #15 on: February 16, 2012, 03:35:22 PM »
Brett :
I slide the tank in from the front also - 45 degree angle.
Offline Matt Colan
« Reply #16 on: February 16, 2012, 05:44:50 PM »
Hi John,
There are ribs in the RSM kit for the warren truss rib design, however, if you build it with Bob Hunts Lost-foam wing, we found the airfoil to be off of what templates he has.  Once all the sheeting and such was in , the original airfoil we traced (the RSM airfoil) is pretty much the same as the template Bob has but with all the sheeting, cap strips etc. on it.  When I head over during the weekend, I'll try and get a picture to show you the difference between the airfoils.
For this plane, since we're using a different type of take apart structure, the fuselage sides couldn't be used because they're designed for the one piece wing take apart system.  Dave Fitzgerald also told me to add 1/4" to the length of the nose compared to what he's been building them at.
« Reply #17 on: February 16, 2012, 06:31:08 PM »
Smart move...
« Reply #18 on: February 17, 2012, 10:43:03 AM »
Thanks for the answer, Matt, are you scrach-building the plane?  D>K
Offline Matt Colan
« Reply #19 on: February 18, 2012, 10:22:58 AM »
It's pretty much half and half.  The wings are pretty much scratch built, and there are new fuselage and plywood doublers. Other than that, I believe almost everything else is from the kit.
« Reply #20 on: February 19, 2012, 07:03:06 AM »
Looking good, Matt, keep the pics coming, very interesting!
Offline Matt Colan
« Reply #21 on: February 19, 2012, 08:16:13 AM »
Here's a couple pictures from yesterday.  John, as promised I took a picture of the two airfoils drawn to show the difference between them.  The longer one is the RSM airfoil and the shorter is Bob Hunt's lost foam template.  I got both the flaps shaped, and we got some clear on the wings and stab and elevators.
